C9115AXE-K settings and error
Translator
Community Manager
Community Manager
In my understanding, the embedded Cisco Wireless AP does not have a separate controller setting device, but by holding an AP as the master, the remaining AP receives firmware and dhcp. I am not sure if I understand this correctly. And I don't know how to set up the GUI environment on the web. I started with the initial setup and connected to the GUI somehow, but I have no idea how to set up the GUI menu and its properties after that. I don't think there's a guide.. Is there any place to get it? And I switched to EWC mode -> ap mode -> capwep mode sequentially and rebooted, but the ap is not booting. Could someone help what's wrong?
marce1000
 - Ref : https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/nb-o6-embded-wrls-cont-ds-cte-en.html , check Table 3 and verify the full model of the acess point, it may not support EWC mode.
 M.
Rich R
C9115AXE does support EWC.
Config guide: https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-6/config-guide/ewc_cg_17_6.html
White paper with some examples: https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
CAPWAP mode AP requires a controller so if you changed the AP to CAPWAP mode then you will need to change it back to EWC mode using the console.
