C9115AXI client problems
Chris.Mes
We have two C9115AXI on remote site, with central WLC C9800. These two C9115AXI are connected to switch C9200 (PoE). No other PoE devices on the switch.
They worked fine for a few month, but now we have strange issue, clients on one of the APs can authenticate, get ip address from DHCP, but they get wrong DNS server, because they get the ip-address of the AP1 as DNS. So they are not able to work.
They even can not ping their default-gw. We've done everything, change cables, switchports, reboot switch, reboot WLC, even change the AP1, but with new AP (same model C9115AXI) we've got exactly the same problem.
And the funny thing is, after reboot of the switch, the problem moved from AP1 to AP2.
So it seems, only one of the AP does work at same time.
Any ideas?
Chris.Mes
Hello!
I think the problem was "Mobility Express", because I also saw additional MAC-address 0000.5e00.0101 on the switch and I saw it in the leases of DHCP. Since I've entered command "ap-type capwap" on the APs they work like expected.
6 Replies 6
balaji.bandi
what you see logs on the controller, do you have enough licenses ?
connect the console to AP and post full logs.
BB
Mark Elsen
 - Have a checkup of the WLC C9800 configuration with the CLI command  show  tech   wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer.               Checkout all advisories!
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
Seems like you have a dhcp issue not really wireless.  When you use dhcp, you either perform a mac address reservation so that your ap's always get the same ip address or you have static and you exclude the ip address of your ap's, gateway and any other devices you might have, like the switch ip as an example.  Devices getting an ip address of your ap or any other device is a problem with your dhcp configuration.
-Scott
Chris.Mes
Hello!
i was guessing the same, but as per your POST - both are working (but only 1 working at a time) - that made me to ignore that AP not running ME.
that is the reason asked complete logs of AP booting.
any way glad you convert in to capwap to fix.
BB
Rich R
Search for other posts about EWC APs unexpectedly switching back from CAPWAP to EWC mode.  Best to re-flash those APs using the recovery software to completely remove EWC.  Also set the option 43 for CAPWAP mode so DHCP always tells AP to use CAPWAP mode.
Note: Mobility Express was the AireOS WLC product on Wave 2 (18xx/28xx/38xx) APs.  The Catalyst 9000 APs run IOS-XE (9800) based EWC for AP.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
