C9130-Multi
ZK916
Level 3
Level 3
This is a rather simple question. We purchased a few Cisco C9130AXI-B WAPs and in packet list it shows the following item:
C9130-MULIT --- Minimum Quantity = 10
What does the "MULTI" refer to?
Thanks in advance.
it means you ordered multi device SKU. so set of APs will deliver in one box. (minimum 10 APs). if normal SKU used, each AP will deliver separately.
Good luck
KB
Good luck
KB
