Mobility Anchor issue between 9800 and 5508 Control Path Down
My environment :
Foreign 9800 - Code version tested - 17.6.4 and 17.3.6
Anchor 5508 - 8.8.130 and 8.5.X
I am having issues while creating tunnel between 9800 ( foreign ) and 5508 ( Anchor ). WLC IPs can ping each other ( data path is up ) but control path is down. Error logs:
2023/01/23 13:32:47.569357 {mobilityd_R0-0}{1}: [mm-dtls] [19101]: (note): Peer IP: 149.x.x.x Port: 16666 DTLS_UNPLUMB: Key unplumb msg sent to FMAN
2023/01/23 13:32:47.569365 {mobilityd_R0-0}{1}: [mm-dtls] [19101]: (note): Peer IP: 149.x.x.x Port: 16666 DTLS_CLEAR_KEY: DTLS keys cleared from MNC and FMAN
2023/01/23 13:32:47.569919 {mobilityd_R0-0}{1}: [mm-dtls] [19101]: (note): Peer IP: 149.x.x.x Port: 16666, Local IP: 157.x.x.x Port: 16666 DTLS_FMAN_ACKNACK: Key unplumb FMAN ACK handled.DTLS connection status: Disabled
2023/01/23 13:32:52.865782 {mobilityd_R0-0}{1}: [mm-dtls] [19101]: (note): Peer IP: 149.x.x.x Port: 16666, Local IP: 157.x.x.x Port: 16666 DTLS_CONNECT: DTLS connection initiated
2023/01/23 13:34:47.570926 {mobilityd_R0-0}{1}: [mm-dtls] [19101]: (note): Peer IP: 149.x.x.x Port: 16666, Local IP: 157.x.x.x Port: 16666 DTLS session not established for 4 intervals. Keepalive status 0. Close DTLS connection.
2023/01/23 13:34:47.571300 {mobilityd_R0-0}{1}: [ewlc-dtls-sess] [19101]: (note): Remote Host: 149.x.x.x [16666] DTLS session destroy
Appreciate help. thanks
Thanks for the recommendations. After much digging we found Mobility group was wrong on the Anchor controller. After it was fixed tunnels came up lightening.
thanks again.
balaji.bandi
I am sure you may have checked the version requirement of the IRCM version.
is this controller behind NAT?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/config-guide/b_wl_17_11_cg/b_wl_17_11_cg_chapter_010000001.html
BB
thanks again.
