C9130AXI GUI Software Management access problem
hertlcrs
Level 2
Level 2
Hi all,
I have running Cisco Embedded Wireless Controller on Catalyst Access Points C9130AXI (17.5.1).
The problem is that I can access the Web GU Software Management, but the page is grayed out and the "Cisco gyroscope" spins and nothing happens!
Have also restarted several times, reseted the config and used different browsers!
Does anyone here have an idea?
Thanks and best Regards
Carsten
hertlcrs
Level 2
Level 2
Solved!
I found the issue!
An AP2802I with an corrupt config caused the issue!
Carsten
9 Replies 9
balaji.bandi
use IE or different browser and test it ?
BB
Thanks for your help, but as I mentioned in the post, I used different browsers, but this does not solve the issue
may be i have over looked, is this come with 17.5.X (or shipped by default ) - can you downgrade and test it ?
Also worth looking verison of browser here :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-5/rel-notes/ewc-rn-17-5-x.html#id_128885
BB
no the Access Point was not shipped with 17.5.1. I had before also other old versions installed.
The issue occured also with the 17.3.1, thats why i tried the 17.5.1
One day the problem occurred, and I do not know why!
I will downgrade to 17.3.4 and try again
Arshad Safrulla
I would definitely try reimagining the AP. Any specific reason to run 17.5.1, I have few running 17.3.X working solid in small branches.
Login to the CLI of the AP and check the CPU and memory utilization, also monitor the logs to see whether it can reveal some info which can be helpful for troubleshooting, or seek for TAC help.
Rich R
what actually solved the problem?
Did you try private browser window (Cisco products are a mess with cookies so many only work correctly in private browser window)?
Does your user have priv level 15?
aaa authorization is not supported by GUI so don't try to use it.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
the problem ist not solved!
yes my user have priv 15
see here:
username mgmtuser privilege 15 secret 9 $9$1l.I2lEM3lIG3k$hQCg0wpy3vV0pmU9pGUDs/G7mweqah9.gKn8Iwgbeqc
Any other ideas?
Now I would like to downgrade with the CLI to 17.3.1, when I execute the command:
"install add profile default"
the following failure message appears:
"FAILED: install_add : Default profile addition failed due to no response from wireless side"
Also here some ideas for me?
hertlcrs
Level 2
Level 2
Solved!
I found the issue!
Carsten
