C9800 and Firebox
Leftz
Level 4
Level 4
Hi Chrome can access WLC9800 without any issue, Firefox cannot. Please see the below. It used to access it. Dont know what happen. The below info is different with what we saw before. In the past, when visiting 9800, we got a warning saying accessing would take some risk, but now it directly shows the below info. Why it happen? Thanks
3 Accepted Solutions
marce1000
       - FYIhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb45089
 M.
 Which Firefox version do you have? Firefox Version 63.x is not supported.
ammahend
it’s cert trust issue, try incognito, if it still doesn’t work, then there is a way to change ssl setting on Firefox
-hope this helps-
6 Replies 6
marce1000
 M.
ammahend
-hope this helps-
Leftz
Level 4
Level 4
Issue resolved. Thanks for your reply, which narrow down the reason.
Care to share what the actual problem was for the benefit of others here?
Leftz
Level 4
Level 4
found some mistake : )
