C9800-L-F-K9 ans Switch 3750x, no connect
nstr1
I have a 9800 wlc and a 3750 x switch.
with a GLC-SX-MMD SFP
I connect the WCL (tengig port 0/1/0) to the switch but in the switc the port does not raise, but the wlc port is seen up.
This is the wlc configuration.
interface Port-channel1
switchport access vlan 1000
switchport mode trunk
interface Port-channel2
description Port-channel2
interface TwoGigabitEthernet0/0/0
negotiation auto
channel-group 2 mode active
interface TwoGigabitEthernet0/0/1
negotiation auto
interface TwoGigabitEthernet0/0/2
negotiation auto
interface TwoGigabitEthernet0/0/3
negotiation auto
interface TenGigabitEthernet0/1/0
switchport trunk native vlan 1000
negotiation auto
interface TenGigabitEthernet0/1/1
negotiation auto
channel-group 1 mode on
interface GigabitEthernet0
vrf forwarding Mgmt-intf
ip address 192.168.1.74 255.255.255.248
negotiation auto
no mop enabled
interface Vlan1
no ip address
shutdown
interface Vlan16
description guest-wlan
ip address 192.168.16.6 255.255.252.0
interface Vlan1000
description VLAN mgmt
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 192.168.1.169
snmp-server community 192.168.1.169 RO
This is the switch configuration.
3750X#sh run int Gi1/1/1
Building configuration...
Current configuration : 116 bytes
interface GigabitEthernet1/1/1
description WLC
end
3750X#sh int Gi1/1/1
GigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 6400.f1f6.6c99 (bia 6400.f1f6.6c99)
Description: WLC
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
3750X#
Why is my port on the switch inactive?
balaji.bandi
what SFP you have inserted in 9800 L port?  if same SX-MMD 1GB SFP
On the port config, 9800 try lower the speed with the command (speed 1000 ) - it works on other platform (9800 i have not tried - but it should work).
BB
Rasika Nayanajith
Did you test this SFP model work on your 3750X series switches (ie if two switches connect using those SFP model, does link come up?). Here is 3750X series supported SFP listed on cisco.com
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/net_mod_note.html#wp129397
The 9800-L-F model listed that is supported SFP, however, I do not see it on 3750X series switch documentation
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/datasheet-c78-742434.html
Rasika
*** Pls rate all useful responses ***
Rich R
This post never got a solution but if you find this you might want to take a look at https://community.cisco.com/t5/wireless/9800-l-f-sfp-10g-interfaces-wont-connect/m-p/4662165 (which links to this one) for some hints.
