C9800-L Not Pushing WLAN Config
NWJ
I have a C9800-L-F-K9 running on 17.9.2 code where not matter what WLAN config I apply within the tag, it will not broadcast on the AP.
Issuing a "show dot11 wlan" directly on the AP shows no thing applied to radios:
L02TEST#show dot11 wlan
Radio Vap SSID State Auth Assoc Switching
0 0 DOWN Central Central Central
0 1 DOWN Central Central Central
0 2 DOWN Central Central Central
0 3 DOWN Central Central Central
0 4 DOWN Central Central Central
0 5 DOWN Central Central Central
0 6 DOWN Central Central Central
0 7 DOWN Central Central Central
0 8 DOWN Central Central Central
0 9 DOWN Central Central Central
0 10 DOWN Central Central Central
0 11 DOWN Central Central Central
0 12 DOWN Central Central Central
0 13 DOWN Central Central Central
0 14 DOWN Central Central Central
0 15 DOWN Central Central Central
1 0 DOWN Central Central Central
1 1 DOWN Central Central Central
1 2 DOWN Central Central Central
1 3 DOWN Central Central Central
1 4 DOWN Central Central Central
1 5 DOWN Central Central Central
1 6 DOWN Central Central Central
1 7 DOWN Central Central Central
1 8 DOWN Central Central Central
1 9 DOWN Central Central Central
1 10 DOWN Central Central Central
1 11 DOWN Central Central Central
1 12 DOWN Central Central Central
1 13 DOWN Central Central Central
1 14 DOWN Central Central Central
1 15 DOWN Central Central Central
I have tried upgrading to 17.9.3 which had no effect. I associated the AP with a 9800-40 running the same version and there was no issue.
Checked country code config also as that can effect broadcasting on some models. I wanted to see if anyone has had this issue previously. I would love to stick to an earlier MD release but this is the only version that supports 9164APs that we are planning to deploy.
17 Replies 17
Rich R
I have 17.9.3 running on 9800-80 and no problems so far!
Will be keen to hear what it turns out to be.
marce1000
                       - Note that  for the C9800-L-F-K9 models , also make sure that :
                 https://software.cisco.com/download/home/286321399/type/282046486/release/16.12(3r)
                 https://software.cisco.com/download/home/286321399/type/283425232/release/17.11.1
                             are up to date and or installed ,
 M.
See https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html#toc-hId-1999087437 for more info on that firmware and https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_upgrade_fpga_c9800.html
