Cant create WLAN Interface
adilhayat
I m using WLAN 4400 with4.1.185.0 code. I tried to create on more interface, it says "cant creat the port".
However, it creates the port but does not take DHCP IP. It is also broadcasting that SSID. Any solution ?
Many Thanks
Hi Muhammad,
I just tried and it on my WLC and its working fine..
Correct me if i am wrong.. i assume that you are configuring like this..
step1 >> Controller >> interfaces >> new >> Fill in the data >> with DHCP address and all those.
Step2 >> Controller >> WLAN >> New >> Map the dynamic interface which you created to this WLAN.
Correct??
Surendra
Surendra BG
9 Replies 9
Surendra BG
I need some more info.. are we creating the Dynamic interface or something else?? please lemme know what are we trying to do..
Surendra
Surendra BG
Thanks for your reply. dynamic interface so that I can associate WLAN SSID to this new Interface. I wan to broadcast a new ssid for guests. we do have existing SSIDs but they are authenticated using domain account. Now i m trying to create one SSID that can be authenticated by the controller it self
for guests. Please inform me if u need more info.
Hi Muhammad,
Correct??
Surendra
Surendra BG
yes, exactly. Actually I have done it several times on 5500, but on this 4400, its giving this error. It does create but is not taking DHCP address, after apply when I check , this dhcp field is blank.
it will be great if you could paste the screenshot here!!
Surendra
Surendra BG
Dear Surendra
Thanks for your reply. I was not filling physical interface field. LAG is disabled here, so I have to enter interface number.
ok So i guess now the issue is resolved!!
Surendra
Surendra BG
yup
Thats nice to hear!!  have a great day..
Surendra
Surendra BG
