CAP1552E with CT5508
Debudas123
      i have 12 nos CAP3602I, 4 nos of CAP1552E and CT5508 , i have added all the indoor caps (3602I) in controller, but outdoor caps (1552E) are not adding, so anyone please help me.
thanks
Debu
34 Replies 34
where is the mode botton? only one reset botton is there...
thanks
debu
do it via Reset button.
Reagrds
nothing happens..
thanks
Debu
First check if the is checked?   security > AP Policy ---> Accept Manufactured Installed  Certificate (MIC)
1.  paste the log again ?
2. SH VERSION  and the logs from console.
3.Also paste the screenshot of this page: security > AP Policy
log
*Feb 11 14:48:40.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_
dtls_connection_db.c:2051 Max retransmission count reached!
*Feb 11 14:48:45.099: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Feb 11 14:48:45.099: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Feb 11 14:48:45.099: %MESH-6-LINK_UPDOWN: Mesh station 189c.5d8f.e09c link Down
*Feb 11 14:49:10.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
10.3.2:5246
*Feb 11 14:49:10.999: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 11 14:48:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.10.3.2 peer_port: 5246
% CDP is not supported on this interface, or for this encapsulation
*Feb 11 14:48:25.483: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.
10.3.2:5246
*Feb 11 14:48:25.483: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Feb 11 14:48:25.583: %LWAPP-3-FALLBACK_DHCP: Invalid Static Gateway, so fallbac
k to DHCP.
*Feb 11 14:48:37.587: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 11 14:49:38.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
version
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 15.2(2)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 04:59 by prod_rel_team
Initializing flashfs...
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
AP189c.5d8f.e080 uptime is 14 minutes
System returned to ROM by power source change
System image file is "flash:/c1520-k9w8-mx.152-2.JB3/c1520-k9w8-xx.152-2.JB3"
Last reload reason:
--More--                           agree to comply with applicable laws and regulations. If you are unable
--More--                           to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1552E-N-K9    (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1802P1HW
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power source change
LWAPP image version 7.4.121.0
AVR Microcontroller 1 - SW Version: 00.01.02
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 18:9C:5D:8F:E0:80
Part Number                          : 73-13538-02
--More--                           PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC17506W6T
Top Assembly Part Number             : 800-34851-05
Top Assembly Serial Number           : FTX1802P1HW
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-N-K9
Configuration register is 0xF
AP189c.5d8f.e080#
okay
now its working...
but when i have configure 1 RAP and 1 MAP both are not connecting into mess network, what will be the issue ?
thanks
Debu
Glad that worked...
Here is the guide for mesh deployment:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1522-lightweight-outdoor-mesh-access-point/113678-wlan-mesh-config-ex.html
Reagrds
Dont forget to rate helpful posts and mak this question as answered, it may help others.
but now some error is showing in MAP's console
e from controller
*Feb 11 17:56:48.919: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
acket from 10.10.3.2
*Feb 11 17:57:10.807: %CAPWAP-3-ERRORLOG: Unencrypted non-discovery CAPWAP Contr
ol Message from 10.10.3.2
*Feb 11 17:57:10.807: %CAPWAP-3-ERRORLOG: Invalid AC Message Type 34078720.
*Feb 11 17:57:10.807: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Feb 11 17:57:10.807: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
*Feb 11 17:57:25.539: %CAPWAP-3-ERRORLOG: Unencrypted non-discovery CAPWAP Contr
*Feb 11 17:57:25.539: %CAPWAP-3-ERRORLOG: Invalid AC Message Type 34078720.
*Feb 11 17:57:25.539: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Feb 11 17:57:25.539: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
*Feb 11 17:57:48.919: %CAPWAP-3-ERRORLOG: Unencrypted non-discovery CAPWAP Contr
*Feb 11 17:57:48.919: %CAPWAP-3-ERRORLOG: Invalid AC Message Type 34078720.
*Feb 11 17:57:48.919: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Feb 11 17:57:48.919: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
e from controller
e from controller
e from controller
e from controller
is this connected to controller ???
did you changed the role for an access point from WLC ??
dont forget to rate helpful posts
  this ap is not connected with controller, it is connected with root ap.
yes i have change the role of the ap from controller.
Debu
another issue is there users are unable to connect the wi-fi, ssid's are showing, but unable to connect, and still showing the following error
e from controller
*Feb 12 10:06:44.595: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
*Feb 12 10:06:55.211: %CAPWAP-3-ERRORLOG: Unencrypted non-discovery CAPWAP Contr
*Feb 12 10:06:55.211: %CAPWAP-3-ERRORLOG: Invalid AC Message Type 34078720.
*Feb 12 10:06:55.211: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Feb 12 10:06:55.211: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
e from controller
e from controller
Debu,
Did you add the MAC address of both mesh APs to the Mac filter list? Did you have bother connected on the network wired so that they can join the WLC and download the code? Do you have AC power adapter, correct power injector or the right power source to power up these AP's, if not, the radios will not come up. Also make sure you have the antennas connected. Do you also have any other AP's joined to this WLC?
-Scott
  everything is okay, but still showing the error.
Debu
Everything is working fine, its just the error that your concerned with?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
yes..
thanks
