Carrying VLANs over Wireless bridge
fcoppotelli
I've deployed a wireless bridge using 2 Aironet Bridge 1310, configured with 4 sub-interfaces to carry 4 Vlans over the radio bridge.
The native VLAN is the VLAN 1, it's rightly configured on the trunk interfaces but I cannot ping the directly connected switch.
[switch]--f0/24--[root bridge]-----RADIO-----[non-root bridge]--f0/24--[switch]
Following the AP root configuration:
dot11 ssid bridge
vlan 1
authentication open
infrastructure-ssid
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid bridge
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
distance 1
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
interface Dot11Radio0.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 101
bridge-group 101 subscriber-loop-control
bridge-group 101 block-unknown-source
no bridge-group 101 source-learning
no bridge-group 101 unicast-flooding
bridge-group 101 spanning-disabled
interface Dot11Radio0.201
encapsulation dot1Q 201
no ip route-cache
bridge-group 201
bridge-group 201 subscriber-loop-control
bridge-group 201 block-unknown-source
no bridge-group 201 source-learning
no bridge-group 201 unicast-flooding
bridge-group 201 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface FastEthernet0.10
no ip route-cache
interface FastEthernet0.101
no ip route-cache
bridge-group 101
interface FastEthernet0.201
no ip route-cache
bridge-group 201
interface BVI1
ip address 10.116.162.181 255.255.255.224
no ip route-cache
The problem is that I cannot ping the root access point from the switch.
SWITCH PORT CONFIGURATION:
interface GigabitEthernet0/1
description LINK TO CORE SWITCH 4507
switchport trunk allowed vlans 1,10,101,201
switchport trunk native vlan 1
carlosmadriz
does the switchport also belongs to vlan 1?
is there an ...interface vlan 1,ip address X.X.X.X sm.sm.sm.sm,no shut... configured on the switch?
check if the dot1q trunk is recogniced by the switch with "show int trunk"
AJAZ NAWAZ
Level 5
Level 5
Hi there.
Did you find a solution to this issue please?
thanks
