Catalyst 9300 EWC Programmability and Telemetry?
SondreSandberg
Level 3
Level 3
Does the 9300 EWC (embedded wireless controller on Catalyst 9300 switch) support gNMI as model-driven configuration management?
Found this documentation, but it does not mention embedded wireless controller on switches.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/catalyst-9800-programmability-telemetry-deployment-guide.html
Scott Fella
From the guide you posted, it tells me that the wireless portion is not supported on the 9300 switch.  You would have to look at the switch programability guide to see what is supported on that: Programmability Configuration Guide, Cisco IOS XE Bengaluru 17.6.x - gNMI Protocol [Cisco IOS XE 17] - Cisco
Might be a something you reach out to your Cisco rep or open a TAC case to see what they say.
-Scott
Scott Fella
Seems like from this link, only netconf + yang is supported,
Products - Cisco Embedded Wireless Controller on Catalyst Switches (Non-SD-Access) Deployment Guide - Cisco
-Scott
Rich R
So the first question: are you trying to use it as a standalone WLC (non-SDA) or SDA?
Cisco has end of life'd the standalone version of switch EWC as per the link Scott shared above.  Last support was 17.3 and no more development.  Since gNMI only came in 17.6 you definitely won't find it in 17.3.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
