Trying to place a SSID into 5Ghz only via CLI
JWHolm81891
I am having trouble trying to find a CLI command that will let me config a WLAN/SSID into 5Ghz only:
Radio Policy                                   : 802.11a only
I've tried the GUI disableing the 2.4, but I'm still getting:
Operational State of Radio Bands
    2.4ghz                                     : UP
    5ghz                                       : UP
    6ghz                                       : DOWN (Required config: Disable WPA2 and Enable WPA3 & dot11ax)
How can I configure this for 802.11a only and get that in my config output for confirmation?
17 Replies 17
Scott Fella
The configuration is done on the WLAN.  The radios will show up, but the SSID will not be broadcasting from the 2.4GHz radio.  802.11a only is what you need to have configured.
I don't know what controller you have, but for Aireos, you can shutdown the radio by using the following command:
config 802.11b disable <ap-name>
-Scott
I am working with the 9800 controller. But that only disables per AP right? What if I want to do that for a WLAN?
What you have defined on the WLAN is fine, that is all you need to do... 802.11a only That way you can have another SSID that uses both bands if needed.  You have more flexibility configuring this on the WLAN than manually disabling the radio which affects all other SSID on the AP.
-Scott
Maybe I'm misunderstanding your reply. I have on that is configured 802.11a only, but I didn't configure that one. I have another SSID that I am trying to configure like that so that it is only 802.11a. Does that make sense?
Not really... what I'm trying to say is that on the WLAN, you defined what radios you want to use.  In your case, you have 802.11a only, so that means that SSID will be available out on the 5GHz radio.  The 2.4GHz will show up, but that doesn't mean that the SSID is available on that radio.
-Scott
Does this help?  If you want the SSID to only use 802.11a, you setup your WLAN like this:
-Scott
What you can do is create a new SSID with your setting and then apply that.  Then go to save and click on diff.  That will show you the output and commands, just like this:
-Scott
Right, and I've done that. But when going in to read the configs 2.4 still shows as UP:
    2.4ghz                                     : UP
    5ghz                                       : UP
I'm on the 17.6.2. I don't seem to have that disable Wifi 6 option.
Operation mean that the 2.4GHz is available if you want to use it.  Basically, the ap radio is not just for the one ssid but its used for all ssid's. All you care about is this: Configured Radio Bands
show wlan all | sec Network Name|Configured Radio Bands|Operational State of Radio Bands
-Scott
WiFi 6 option os on later code versions to support the 9136 as an example.  Why not create a new SSID and post that test SSID config from the command line.  I can then add that to my controller and see.
-Scott
Scott Fella
So when I run the command on my controller is do not see the 2.4ghz like what you see on yours.  Post your test SSID so I can add it to mine and validate.
I'm on 17.10.1prd4
WA-RED-9800-L-01#show wlan id 265 | sec Network Name|Configured Radio Bands|Operational State of Radio Bands
Network Name (SSID) : 5GHz Only
5ghz : Enabled
Slot : Enabled on all slots
5ghz : UP
-Scott
Thank you
The one on 802.11a only:
show wlan all | sec wlan id 10|Configured Radio Bands|Operational State of Radio Bands
Configured Radio Bands : All
2.4ghz : UP
5ghz : UP
The one I'm trying to get on 5Ghz only:
#show wlan all | sec wlan id 2|Configured Radio Bands|Operational State of Radio Bands
2.4ghz : UP
5ghz : UP
My output looks different from yours.
Doesn't look right, because the Configured Radio Bands show All and not 802.11a only.  Can you paste your
show run | sec <SSID>
Take a look at mine:
wlan "5GHz Only" 265 "5GHz Only"
dot11ax target-waketime
dot11ax twt-broadcast-support
radio policy dot11 5ghz
no security ft adaptive
no security wpa
no security wpa wpa2
no security wpa wpa2 ciphers aes
no security wpa akm dot1x
-Scott
I think you were nice enough to have a look at these yesterday and saw the one in 802.11a only. I'm just trying to figure out how to get the other the same.
#sh run | sec-Managed
aaa authentication dot1x DOT1X_AUTH_-Managed group _Managed
 wlan NPS--Managed policy POLICY_PROFILE_13
 wlan NPS-C-Managed policy POLICY_PROFILE_13
wlan NPS--Managed 10 -Managed
 radio dot11a
 security wpa wpa1
 security wpa wpa1 ciphers aes
 security dot1x authentication-list DOT1X_AUTH_-MANAGED
 no shutdown
#sh run | sec Mobile
wlan WL-Personal 2 Mobile
 security wpa psk set-key ascii 0 personal
 security wpa akm psk
 security pmf optional
 no shutdown
WLAN Profile Name     :Personal
Identifier                                     : 2
Description                                    :
Network Name (SSID)                            :Mobile
Status                                         : Enabled
Broadcast SSID                                 : Enabled
Advertise-Apname                               : Disabled
Universal AP Admin                             : Disabled
Max Associated Clients per WLAN                : 0
Max Associated Clients per AP per WLAN         : 0
Max Associated Clients per AP Radio per WLAN   : 200
OKC                                            : Enabled
Number of Active Clients                       : 110
CHD per WLAN                                   : Enabled
WMM                                            : Allowed
WiFi Direct Policy                             : Disabled
Channel Scan Defer Priority:
  Priority (default)                           : 5
  Priority (default)                           : 6
Scan Defer Time (msecs)                        : 100
Media Stream Multicast-direct                  : Disabled
CCX - AironetIe Support                        : Disabled
Peer-to-Peer Blocking Action                   : Disabled
    2.4ghz                                     : UP
    5ghz                                       : UP
DTIM period for 802.11a radio                  :
DTIM period for 802.11b radio                  :
Local EAP Authentication                       : Disabled
Mac Filter Authorization list name             : Disabled
Mac Filter Override Authorization list name    : Disabled
Accounting list name                           :
802.1x authentication list name                : Disabled
802.1x authorization list name                 : Disabled
Security
    802.11 Authentication                      : Open System
    Static WEP Keys                            : Disabled
    Wi-Fi Protected Access (WPA/WPA2/WPA3)     : Enabled
        WPA (SSN IE)                           : Disabled
        WPA2 (RSN IE)                          : Enabled
            MPSK                               : Disabled
            EasyPSK                            : Disabled
            AES Cipher                         : Enabled
            CCMP256 Cipher                     : Disabled
            GCMP128 Cipher                     : Disabled
            GCMP256 Cipher                     : Disabled
            Randomized GTK                     : Disabled
        WPA3 (WPA3 IE)                         : Disabled
        Auth Key Management
            802.1x                             : Disabled
            PSK                                : Enabled
            CCKM                               : Disabled
            FT dot1x                           : Disabled
            FT PSK                             : Disabled
            Dot1x-SHA256                       : Disabled
            PSK-SHA256                         : Disabled
            SAE                                : Disabled
            OWE                                : Disabled
            SUITEB-1X                          : Disabled
            SUITEB192-1X                       : Disabled
    CCKM TSF Tolerance (msecs)                 : 1000
    OWE Transition Mode                        : Disabled
    OSEN                                       : Disabled
    FT Support                                 : Disabled
        FT Reassociation Timeout (secs)        : 20
        FT Over-The-DS mode                    : Disabled
    PMF Support                                : Optional
        PMF Association Comeback Timeout (secs): 1
        PMF SA Query Time (msecs)              : 200
    Web Based Authentication                   : Disabled
    Conditional Web Redirect                   : Disabled
    Splash-Page Web Redirect                   : Disabled
    Webauth On-mac-filter Failure              : Disabled
    Webauth Authentication List Name           : Disabled
    Webauth Authorization List Name            : Disabled
    Webauth Parameter Map                      : Disabled
Band Select                                    : Disabled
Load Balancing                                 : Disabled
Multicast Buffer                               : Disabled
Multicast Buffers (frames)                     : 0
IP Source Guard                                : Disabled
Assisted-Roaming
    Neighbor List                              : Enabled
    Prediction List                            : Disabled
    Dual Band Support                          : Disabled
IEEE 802.11v parameters
    Directed Multicast Service                 : Enabled
    BSS Max Idle                               : Enabled
        Protected Mode                         : Disabled
    Traffic Filtering Service                  : Disabled
    BSS Transition                             : Enabled
        Disassociation Imminent                : Disabled
            Optimised Roaming Timer (TBTTS)    : 40
            Timer (TBTTS)                      : 200
        Dual Neighbor List                     : Disabled
    WNM Sleep Mode                             : Disabled
802.11ac MU-MIMO                               : Enabled
802.11ax parameters
    802.11ax Operation Status                  : Enabled
    OFDMA Downlink                             : Enabled
    OFDMA Uplink                               : Enabled
    MU-MIMO Downlink                           : Enabled
    MU-MIMO Uplink                             : Enabled
    BSS Target Wake Up Time                    : Enabled
    BSS Target Wake Up Time Broadcast Support  : Enabled
802.11 protocols in 2.4ghz band
    Protocol                                   : dot11bg
Advanced Scheduling Requests Handling          : Enabled
mDNS Gateway Status                            : Bridge
WIFI Alliance Agile Multiband                  : Disabled
Device Analytics
    Advertise Support                          : Enabled
    Advertise Support for PC analytics         : Enabled
    Share Data with Client                     : Disabled
Client Scan Report (11k Beacon Radio Measurement)
    Request on Association                     : Disabled
    Request on Roam                            : Disabled
WiFi to Cellular Steering                      : Disabled
Locally Administered Address Configuration
    Deny LAA clients                           : Disabled
wlan Personal / Mobile
 security wpa psk set-key ascii 0 WLpersonal
 no shutdown
FASTER VLAN (the one I’m trying to match)
WLAN Profile Name     : NPS-Managed
Identifier                                     : 10
Description                                    :
Network Name (SSID)                            : Managed
Status                                         : Enabled
OKC                                            : Enabled
Number of Active Clients                       : 26
WMM                                            : Allowed
802.1x authentication list name                : DOT1X_AUTH_Cityof-MANAGED
Security
        WPA (SSN IE)                           : Enabled
            TKIP Cipher                        : Disabled
            MPSK                               : Disabled
            EasyPSK                            : Disabled
        Auth Key Management
            802.1x                             : Enabled
            PSK                                : Disabled
            CCKM                               : Disabled
            FT dot1x                           : Disabled
            FT PSK                             : Disabled
            SAE                                : Disabled
            OWE                                : Disabled
    OSEN                                       : Disabled
    FT Support                                 : Adaptive
    PMF Support                                : Disabled
Assisted-Roaming
            Timer (TBTTS)                      : 200
802.11ax parameters
    Protocol                                   : dot11bg
Device Analytics
wlan NPS-Managed 10 Managed
 radio dot11a
 security wpa wpa1
 security dot1x authentication-list DOT1X_AUTH_MANAGED
 no shutdown
