Catalyst 9800 iPSK without RADIUS
steve.blunt
Level 3
Level 3
Does anyone know if it is possible yet to leverage iPSK on Catalyst 9800 without the need for ISE integration? The ask form one of our customers is:
- To be able to leverage a single SSID with up to 10 separate iPSK groups, with the ability to assign each iPSK group to a different VLAN and apply a per VLAN based QoS policy. The end user devices should not leverage a http/https on boarding portal or usage policy splash screen as some devices will not support web interfaces i.e. they are IoT appliances. The end users will not have time to provide their devices MAC address in advance nor be burdened with the need to do so once on site.
So the required access is effectively PSK based in the 2.4 and 5 Ghz spectrums, iPSK groups map to a VLAN/QoS policy. A Cisco UDN Plus solution is not practical.
The customer has the latest series 91xx APs, 9800 WLC, Catalyst Centre with Advantage licensing.
Is the above configuration possible, are there any scaling issues or dependencies?
Many thanks
you need ISE or radius for iPSK
MHM
Mark Elsen
  - Check if this can help you : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh18572
    + This being for Meraki but perhaps it can contain useful elements : https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_Authentication_without_RADIUS
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Jason Tyler
The solutions currently supported in the 9800 rely upon Mac address.
If you have ISE, then a non-cisco supported tool such as ipsk manager can work with ise to simplify the Mac address overhead.
But, yes, the iPSK feature can work with other radius servers, e.g. FreeRadius - if that is your question?
Your challenge remains though, with the overhead and management of the Mac addresses - you will need to create a list of MAC in the AAA server to authorise these devices. But then does give you the flexibility to assign vlan etc from the AAA server.
Or were you asking if this can be natively done on the 9800 itself ?
MPSK allows upto x5 separate PSK to be enabled upon a single ssid - no need for any Mac address, and does not need AAA servers etc, but there is no ability to drop these clients into separate vlans using this method either.
On the meraki side, they do have a solution call WPN that does not rely upon Mac addresses, but as you have catalyst, it is unlikely you can take advantage of this approach.
9800 did have a solution called easy-psk that was only ever introduced as a beta in 17.6 code (info in the config guide for 17.6 only)
EasyPSK is still radius based, and only works when the AP is in Local Mode - not supported at all if the AP is in Flexconnect Mode.
Nice guide for doing iPSK with FreeRadius: https://goodwi.fi/posts/2023/09/ipsk-no-ise-freeradius/
More discussion here https://www.reddit.com/r/Cisco/comments/1bznm8m/wifi_devices_without_wpa23_enterprise_mpsk_ipsk/
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
MHM
