Catalyst 9800 on Hyper v issue
guidov2
Frequent Visitor
Frequent Visitor
Strange issue with Catalyst 9800 hosted on Hyper v:
Interfaces doesn't work in switch port mode:
if interfaces are configured in switchport mode (access or trunk) it seem there is no transmission to the outside.
In routing mode it works correctly.
Already installed on other VM (not Hyper v) without issue.
from WLC we can see the arp table is populated .. but other devices cannot see its mac address and there is no entry in apr table.
with FIA packet trace we can see
Drop with reason 493.
in attach screenshot of packet capture
 Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/16-12/release-notes/rn-16-12x-9800.html#id_114714
 It seems that if you look at the Supported Hardware hardware section that Hyper-V is not listed, whilst in
 https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/release-notes/rn-17-1-9800.html#id_114714
Supported Hardware section it is mentioned that you need (see tabled  output below). This implies that your version does not yet support Hyper-V and that you will need 17.1.x at least to start with.
Microsoft Hyper-V
Windows Server 2016 (Version 1607) with Hyper-V Manager (Version 10.0.14393)
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
16 Replies 16
Mark Elsen
 - Carefully review installation guidelines, and needed resources from the document below; also pay attention to the section Configuring Tagged ports :
   https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/9800-cloud/installation/b-c9800-cl-install-guide/b-c9800-cl-install-guide_chapter_01011.html
 M.
reviewed few time the installation guidelines.
tagged ports configured in powershell as the example:
Get-VMNetworkAdapter -VMName <C9800-name>
for trunk port:
Set-VMNetworkAdapterVlan -VMName “C9800” -VMNetworkAdapterName Eth1 -Trunk -AllowedVlanIdList “1-4000” -NativeVlanId 0
for access port (management):
-VMName “C9800” -VMNetworkAdapterName Eth0 -Untagged
Any other ideas ?
 - Also check and or lookup compatibility between 9800-virtual version being installed and hyper v version currently in place.
 M.
I cannot find the compatibility matrix for Hyper v with 9800 version.
9800 version is 6.12.02s
do you have any link for this ?
Thanks and regards
Guido
guidov2
Frequent Visitor
Frequent Visitor
sorry for typo
16.12.02s not 6.12.02s
I can't see any compatibility matrix either. Presume you've checked the Hardware and VM Requirements and Network Connectivity Issues sections in https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/9800-cloud/installation/b-c9800-cl-install-guide/troubleshooting.html
There's a bit of info on vNICs and switches at https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html#Features
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Microsoft Hyper-V
Well spotted - I didn't check the release notes - duh! 🙂
Thank You Marce,
I have the same problem too.
we check !
Roberto
Thank you
this explain the issue
guidov2
Frequent Visitor
Frequent Visitor
I spoke too early.
it doesn't work also with 17.x train
Hosting machine is widows server 2019 1809 build 17763 v. Hyper v manager10.0.1763.1 (switch embedded teaming )
Issue is: from int g1 (routed mode) all works fine - g2 (trunk - native vlan 21).
it is like it receive packets but they are not sent
any vlan on trunk can see mac addresses on its vlan but other devices cannot see the 9800 mac
for example default gateway for each vlan does not see arp entri of vlan configured on 9800
thanks and regards
 - As this is all fairly new from the controller-versioning side and the hyper-v support, you may want to take these issue up with Cisco TAC.
 M.
 - Also note that you are not using the exact specified hyper-v environment in terms of windows and hyper-v versions. This is tricky. Usually things are upwards compatible, but for specialized appliances this is not always true. They for instance need to be certified for later versions of windows and hyper-v. You need authoritative confirmation from TAC that it will work on your hyper-v environment.
 M.
