CBW 150AX and CBW145AC
pafanelli
Hello community,
I've a wireless network done by 150AX and 151AXM. It works fine. Now I've to add on the same network a CBW 145AC because need few eth ports in an specific area.
Is there a way to do that ?
Thank you in advance for your time and support.
Hello Bandi,
I didi it but doesn't work. What's why 150AX doesn't support 145AC as subordinate AP.
Thus I ask this technical community if there is a workaround or trick. Two Primary APs can't exist on the same network, but where is a way to avoid one AP listen the other ? I tried to set up in Wireless Settings->Wllan Users->Local MAC address the other MAC Address as Blocklist type but doesn't work; you can clearly see in the Logging a WCAP packet arrived and ignored because the other AP model in not supported.
Any other suggestion ? I'm willing to configure one AP off-line and not manage it by GUI (blindly), the important is it publish out own SSID and works as standalone AP
I don't have a L3 router so both APs have to stay on the same network.
Thank you in advance,
