Cisco 3802I model supports 2960 series switches ?
Hi Everyone,
Could you please help and let me know whether the Cisco 3802I AP supports Cisco 2960 series PoE switches?
5 Replies 5
aamir1987ansari@gmail.com hi please share the exact switch model number. you can find that in '#sh version' output and '#sh inventory' output
Good luck
KB
balaji.bandi
check the powere requirement for the AP 3800 models - as Long as Switch has that capabilities then AP can work as expected
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01010.pdf
Note : AP power on does not mean ap working as expected, AP need correct power requirement to work as expected.
BB
Thanks Balaji
Rich R
As the others have pointed the exact model of 2960 switch matters.
3802 requires 802.3at (POE+) 30W PoE power source with CDP or LLDP enabled for full operation.
Refer to the datasheet for more info:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3800-series-access-points/datasheet-c78-741682.html#Productspecifications
Input power requirements
●  802.3at PoE+, Cisco Universal Power over Ethernet (Cisco UPOE ®)
●  802.3at power injector (AIR-PWRINJ6=)
●  50W power supply (AIR-PWR-50=)
Power draw
●  25.8W at the PSE (22.5W at the PD) with all features enabled except for the USB 2.0 port
●  30W at the PSE (25.5W at the PD) with the USB 2.0 port enabled
Thanks Rich to provide this
