central switching NOT work.
Good mooring,
My lab is:
1)  Virtual controller 7.3.112  is OK
2)  N° 2 LAP 1130 e 1240   is Joined to controller OK
3)  flexconnect in localswitch is OK
4)  flexconnect in central switch IS NOT work.
please can you help me to find the problem.
David Watkins
Level 8
Level 8
Did you follow the deployment guide for the vWLC ensuring things like promiscuous mode on your vSwitch and appropriate VLAN tagging is specified on your virtual network?
http://www.cisco.com/image/gif/paws/113677/virtual-wlan-dg-00.pdf
The scenario you described should work find if all items are configured as the guide describes.
Scott Fella
I bet its an issue with your virtual switch configuration. Maybe test it out by mapping it to the management interface. This way since your vWLC is up, you should be able to get this working as a test.
-Scott
I fixed the problem.
the problem was "Promiscuous Mode" of the "data port" Port-group.
this is very impacted solution, because this requirements t is not married to the same logic virtualization.
I have the hypervisor implemented as " best practics" of Cisco and VmWare:
only one port-channel on vswitch with aggregation of ALL NiC ( in only one VSwitch) of the server for I/O traffic client-server.
I can not reserve the Phisycal interface for to made new Vswitch dedicated to this news virtual machine.
this is and requirements very strange for virtualization implementation.
