Change Transmit signal Level on 2702 AP
gl_al
Hi All!
Tell me please, can i adjust the signal level on the  AIR AP 2702? I use Lightweight firmware. Becouse when notebook connect to AP my connection speed no more than 72Mbit, mobile device connection speed 65 Mbit.
Leo Laohoo
This value is dependent on a lot of things:
1.  What Data Rates are enabled;
2.  Distance from the AP;
3.  What radio is the client connected to, 2.4 Ghz or 5.0 Ghz;
4.  What chipset is the wireless client capable of;
5.  Co-channel interference.
my distance to AP 5-7m , my mobile device support Wi-Fi 802.11n, notebook have intel AC dual band 3168. All ap configure with wlc 5760
When performing the speed test, what radio were the clients connected on, 2.4 Ghz or 5.0 Ghz?  (NOTE:  Don't give an answer of "802.11n".)
Intel 3168 is only 1x1.  The best you can do with this is about 125 Mbps.  Tops.
What firmware is the wireless NIC running on?
I check again and my colleague with Sony xperia connect 107 Mbit. I will continue to test maybe my device that working.
