Channels for each vlan-ssid
trih
I have a 1602i acces point with 3 vlans and a ssid per vlan.
Is it possible to set channels for each ssid?
Jonas Kalldert
Hello trih,
Sorry no. Each AP can only run 1 2.4ghz and 1 5ghz channel. Or if you have a FRA capable AP you can run two 5ghz radios (acting as two APs). But you can not run one channel per SSID. Only way to do that would be to have tree APs only broadcasting one SSID each.
regards,
Jonas
**Don't forget to rate helpful posts**
Mikey Boy
No, it doesn't work like that a channel is assigned at radio level. So on the 1602 you have 1 2.4Ghz radio and 1 5ghz radio.
So there will 1 channel on each one (ignoring other factors like bonding on 5Ghz anyway).
