06-10-2019 04:35 PM - edited 07-05-2021 10:32 AM
I have a WLC 3504 v8.5.140 I want to intergrase to the prime 2.2 but it shows me "Cisco device without support"
in
Reachability: marked in green
Admin status: managed
Last inventory collection: "unsupported cisco device"
Why do you show me this message? Is that why I do not see the APs of that WLC in the prime ??unsupported cisco device
Solved! Go to Solution.
06-10-2019 08:10 PM
Hi.
The 3504 WLC was first supported in prime 3.2 and will not work on prime 2.2.
To have the 3504 wlc in prime you need to upgrade to 3.2 or newer.
regards,
Jonas
**Don't forget to rate helpful posts**
06-10-2019 08:10 PM
Hi.
regards,
Jonas
