Cisco 1130 ag - The system is not configured to boot automatically
glicka
I have a problem on a 1131ag Access point on recycle it stops and makes me maunually type BOOT at the ap: prompt
----------VVVVVVVVVVVVV----------------
ap: Xmodem file system is available.
flashfs[0]: 282 files, 13 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 9497088
flashfs[0]: Bytes available: 6501888
flashfs[0]: flashfs fsck took 33 seconds.
Base ethernet MAC Address: 00:12:d9:2b:39:0c
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
The system is not configured to boot automatically. The
following command will finish loading the operating system
software:
boot
C1130 Boot Loader (C1130-BOOT-M) Version 12.3(2)JA, RELEASE SOFTWARE (fc2)
Compiled Mon 08-Nov-04 12:40 by ccai
[I have to type "boot" here to load system]
ap: boot
Loading "flash:/c1130-k9w7-mx.123-7.JA4/c1130-k9w7-mx.123-7.JA4"...#############
File "flash:/c1130-k9w7-mx.123-7.JA4/c1130-k9w7-mx.123-7.JA4" uncompressed and 0
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.3(7)JA4, RELEASE )
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 05-Sep-06 14:14 by alnguyen
Image text-base: 0x00003000, data-base: 0x00683F60
Initializing flashfs...
flashfs[1]: 282 files, 13 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 9497088
flashfs[1]: Bytes available: 6501888
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
[Legal notes removed]
cisco AIR-AP1131AG-A-K9 (PowerPCElvis) processor (revision B0) with 24566K/8.
Processor board ID FOC08514JMF
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:D9:2B:39:0C
Part Number : 73-8962-06
PCA Assembly Number : 800-24818-06
PCA Revision Number : B0
PCB Serial Number : FOC08514JMF
Top Assembly Part Number : 800-25544-01
Top Assembly Serial Number : FTX0909T049
Top Revision Number : A0
Product/Model Number : AIR-AP1131AG-A-K9
I have already performed the ap: set BOOT etc commands a dozen times with the same results.
It says: The system is not configured to boot automatically.
I've been trying to get this one going for 4 months now..it was knocked out during a power outage while upgrading it.
m.sir
Level 7
Level 7
Try command
no boot manual
in global configuration mode
M.
Hope that helps rate if it does
7 Replies 7
m.sir
Level 7
Level 7
Try command
no boot manual
M.
I didn't know how to get to global configuration mode - I did manage to get there with a bit of guess work.
You use AP: Boot
Let it go through the boot process then at the AP> prompt, [enable] priviledged command set, type in password.
At AP# prompt type [config] then press enter for [terminal] at AP#[config] type NO BOOT MANUAL press [Enter] key and reboot AP.
Question...Do I have to use a WRITE command to write the configuration to CMOS?
I did just play it safe.
Yes you need save settings
AP#write
M.
What if the AP is in lightweight mode?  It does not let you into global configuration mode, and I cannot find any settings for changing the boot in this mode.   I am hoping this doesn't require reverting the AP back to autonomous just to make that adjustment...
When an ap is lightweight mode, you will not be able to configure that ap.  The WLC will be the one that will manage the ap.  So dedpending on what code is on the WLC, that is the code the AP will download and use.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks Scott, I just didnt think the WLC had that as a configurable variable, but I can see that once the AP is connected to a controller those commands start to become available within the CLI on the AP.  It just cannot be adjusted if the lightweight AP has not connected to a controller, but who does that?
Brian
I had same problem and it works!
