Cisco 1552EU-E 2.4 Ghz Weak Signal
radu.ioncu
I have just installed a Cisco 1552EU-E outdoor access point with the standard antennas: AIR-ANT2480V-N and AIR-ANT5180V-N. The 5 Ghz signal is great and still strong (-65 dB) even 100 meters away, however the 2.4 Ghz signal is beyond weak - 4 meters from the AP and it is barely visible. The 2.4 Ghz network is enabled from the WLC and everything looks ok settings-wise. The AP is configured in Flexconnect local switching with a virtual WLC.
Has anyone encountered simmilar issues and found a solution or root cause?
Thanks!
7 Replies 7
Scott Fella
From the data sheet, the EU is a single band AP
AIR-CAP1552E-x-K9
802.11N Outdoor Mesh Access Point, Dual band Ext. Antenna
AIR-CAP1552EU-x-K9
802.11N Outdoor Mesh Access Point, Single Band Ext. Antenna
-Scott
Jacob Snyder
Level 5
Level 5
Scott, these are dual band APs. The U stands for uniband antennas. The 1552e has dual band antennas and the EU uses separate 2.4 and 5Ghz antennas on this model.
I would check the power level on the 2.4 radio. You might try manually setting it to power level 1.
Show also might post the results of
> show ap auto-rf 802.11b
I have deployed a second, identical 1552 for the same project and the signal is strong for both 2.4 Ghz and 5 Ghz.
I have conducted a site survey in the vicinity of the 'faulty' 1552, and within 3 meters of the AP the 5 Ghz signal was -39 dB and the 2.4 Ghz signal was -89 dB and flapping. The power level is maxed out (1). I have checked the antenna connections and they are OK. The funny thing is that when I first installed it I quickly tested the connection using my iPhone 5 and a MB Pro, both which connected in the 5 Ghz band and thought everything was OK. However, users with mobile devices without a 5 Ghz radio soon started to complain about poor / non-existent signal.
Do you think I might be dealing with a faulty 2.4 Ghz radio on the 1552?
The result is below of the command is below:
(Cisco Controller) >show ap auto-rf 802.11b xx
Number Of Slots.................................. 2
AP Name..........................................
MAC Address......................................
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
    Channel 1.................................... -100 dBm
    Channel 2....................................  -96 dBm
    Channel 3....................................  -93 dBm
    Channel 4....................................  -98 dBm
    Channel 5....................................  -96 dBm
    Channel 6....................................  -97 dBm
    Channel 7....................................  -96 dBm
    Channel 8....................................  -98 dBm
    Channel 9....................................  -88 dBm
    Channel 10...................................  -89 dBm
    Channel 11...................................  -90 dBm
    Channel 12...................................  -91 dBm
    Channel 13...................................  -94 dBm
--More-- or (q)uit
  Interference Information
    Interference Profile......................... FAILED
    Channel 1....................................  -88 dBm @ 16 % busy
    Channel 2....................................  -85 dBm @ 19 % busy
    Channel 3....................................  -87 dBm @  3 % busy
    Channel 4....................................  -90 dBm @ 13 % busy
    Channel 5....................................  -88 dBm @  2 % busy
    Channel 6....................................  -92 dBm @ 21 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8....................................  -86 dBm @  8 % busy
    Channel 9....................................  -84 dBm @ 21 % busy
    Channel 10...................................  -79 dBm @  2 % busy
    Channel 11...................................  -83 dBm @ 10 % busy
    Channel 12...................................  -84 dBm @  2 % busy
    Channel 13...................................  -91 dBm @  4 % busy
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 2 %
    Channel Utilization.......................... 57 %
    Attached Clients............................. 0 clients
  Coverage Information
    Coverage Profile............................. PASSED
--More-- or (q)uit
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 0 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 0 clients
    SNR   25 dB.................................. 0 clients
    SNR   30 dB.................................. 0 clients
    SNR   35 dB.................................. 0 clients
    SNR   40 dB.................................. 0 clients
    SNR   45 dB.................................. 0 clients
  Nearby APs
    AP 00:24:14:31:d6:00 slot 0..................  -63 dBm on   1 (192.168.2.100)
    AP b4:e9:b0:16:74:e0 slot 0..................  -53 dBm on  11 (192.168.2.100)
--More-- or (q)uit
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Sun Sep 22 03:43:30 2013
    Recommended Best Channel..................... 1
  RF Parameter Recommendations
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Threshold...................... 2346
    Antenna Pattern.............................. 0
  Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  All third party trademarks are the property of their respective owners.
Scott Fella
My bad... I don't know what I was thinking. Any who... The only other thing I would do is make sure that the antennas are indeed the correct one for the 2.4ghz radio. Do you have another 1552 and is that working or are you also seeing the same issue. Post your:
show advanced 802.11b txpower
-Scott
Hi Scott,
I have indeed deployed a second 1552 and the signal levels are as expected. The antennas are connected in the right ports, I could try swapping out the 2.4 Ghz antennas :-?
Thank you!
The output for the command is below:
(Cisco Controller) >show advanced 802.11b txpower
Leader Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. OFF
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... Cisco_01:02:c5 (192.168.2.100)
  Last Run....................................... 291 seconds ago
  TPC Mode....................................... Version 1
  TPCv2 Target RSSI.............................. -67 dBm
  TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
  TPCv2 SOP...................................... -85.0 dBm
  TPCv2 Default Client Ant Gain..................   0.0 dBi
  TPCv2 Path Loss Decay Factor...................   3.6
  TPCv2 Search Intensity......................... 10 Iterations
AP Name                          Channel    TxPower       Allowed Power Levels
--More-- or (q)uit
AIR-CAP1552-BAD                   *1          1/5 (15 dBm) [15/12/9/6/3/0/0/0]
AIR-CAP1552-GOOD                 *11        *1/5 (15 dBm) [15/12/9/6/3/0/0/0]
I would try swaping the antennas just to test.  From the output, the radio is set as 15dbm just like the one that is working fine.  If you swap the antennas and you still have issues, then I would open up a TAC case and tell them what you did and what you have seen and they will probably RMA that 1552.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I have the ANT2480V work with the AP 1562E with a very weak signal too.
My ANT5180V working fine with good signal.
I had make the tx power to level one, and i set the extantenna gain to 16, because this antenna ANT2480V is 8dbi.
I connect it to port 3&4 while the 5G antenna at port 1 & 2.
Any idea what i could change or check for the weak signal?
thank you.
