Cisco 5508 Controller Compatibility with AIR-AP37021
okoroji80
Dear Community Member,
 I want to find out the compactibility of  Access Point ( AIR-AP37021)
AIR-AP3702I-UXK9
802.11ac  AP 4x4:3SS w/CleanAir; Int Ant; Universal
with Cisco WLAN controller 5508 with ios version 7.4.100.0
Feichti
Sorry but this Accesspoint is not supported. See the releasenotes:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn74.html
You need at least Version 7.6 to support the 3702 for the UX Version i dont find anything in the releasenotes.
But for the 2702 with the UX Version the minimum release is 8.0.110.0 so it could be the same for the 3702I-UXK9
Hope it helps.
Yes, You require 8.0.x code for your WLC to get this UX domain AP working. First upgrade your controller to 8.0.121.0 (latest in 8.0.x code)
Then you have to prime your AP first and refer below guide for that.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/AP_Regulatory_Domain_DG/b_universal_AP_regulatory_domain_DG.html
Rasika
*** Pls rate all useful responses ***
