07-09-2021 07:49 AM
some body help I have change new AP with same model in the network when joined to the WLC2504 everything look fine but the radio Oper was Down also cleanAir oper status Down
Solved! Go to Solution.
07-09-2021 08:12 PM
Check the PoE power supply of the AP, and you can also do a cross test.
07-09-2021 08:19 AM
Can you give some information about the failure?
Then on AP2800, you can try to show the following information:
07-09-2021 03:56 PM
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... WLC-2504
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.99.11
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 1 days 8 hrs 43 mins 38 secs
System Timezone Location......................... (GMT +7:00) Saigon, Hanoi, Bangkok, Jakatar
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... TH - Thailand
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +45 C
Fan Status....................................... 4600 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 00:59:DC:B5:11:E0
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
Cisco Controller) >show ap sum
Number of APs.................................... 10
Global AP User Name.............................. admin
Global AP Dot1x User Name........................ Not Configured
AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients DSE Location
APCCI-10 2 AIR-AP2802I-S-K9 00:81:c4:f4:2d:58 default location TH 192.168.99.21 0 [0 ,0 ,0 ]
APCCI-01 2 AIR-AP2802I-S-K9 00:c8:8b:5e:f8:48 default location TH 192.168.99.19 0 [0 ,0 ,0 ]
APCCI-02 2 AIR-AP2802I-S-K9 00:81:c4:6c:b4:bc default location TH 192.168.99.13 0 [0 ,0 ,0 ]
APCCI-04 2 AIR-AP2802I-S-K9 00:81:c4:f4:30:36 default location TH 192.168.99.15 0 [0 ,0 ,0 ]
APCCI-03 2 AIR-AP2802I-S-K9 00:81:c4:6c:d9:00 default location TH 192.168.99.14 0 [0 ,0 ,0 ]
APCCI-08 2 AIR-AP2802I-S-K9 00:81:c4:f4:30:46 default location TH 192.168.99.12 0 [0 ,0 ,0 ]
APCCI-07 2 AIR-AP2802I-S-K9 00:f2:8b:26:ab:fa default location TH 192.168.99.18 0 [0 ,0 ,0 ]
APCCI-05 2 AIR-AP2802I-S-K9 00:2a:10:87:c7:ee default location TH 192.168.99.16 0 [0 ,0 ,0 ]
APCCI-09 2 AIR-AP2802I-S-K9 00:81:c4:6c:d9:0a default location TH 192.168.99.20 0 [0 ,0 ,0 ]
APCCDB.9321.62DA 2 AIR-AP2802I-S-K9 cc:db:93:21:62:da default location TH 192.168.99.52 0 [0 ,0 ,0 ]
(Cisco Controller) >show ap auto-rf 802.11a APCCDB.9321.62DA
Number Of Slots.................................. 2
AP Name.......................................... APCCDB.9321.62DA
MAC Address...................................... cc:db:93:21:62:da
Slot ID........................................ 1
Radio Type..................................... RADIO_TYPE_80211a
Sub-band Type.................................. All
Noise Information
Noise Profile................................ PASSED
Interference Information
Interference Profile......................... PASSED
Rogue Histogram (20/40/80/160)
Load Information
Load Profile................................. PASSED
Receive Utilization.......................... 0 %
Transmit Utilization......................... 0 %
Channel Utilization.......................... 0 %
Attached Clients............................. 0 clients
Coverage Information
Coverage Profile............................. PASSED
Failed Clients............................... 0 clients
--More-- or (q)uit
Client Signal Strengths
RSSI -100 dbm................................ 0 clients
RSSI -92 dbm................................ 0 clients
RSSI -84 dbm................................ 0 clients
RSSI -76 dbm................................ 0 clients
RSSI -68 dbm................................ 0 clients
RSSI -60 dbm................................ 0 clients
RSSI -52 dbm................................ 0 clients
Client Signal To Noise Ratios
SNR 0 dB.................................. 0 clients
SNR 5 dB.................................. 0 clients
SNR 10 dB.................................. 0 clients
SNR 15 dB.................................. 0 clients
SNR 20 dB.................................. 0 clients
SNR 25 dB.................................. 0 clients
SNR 30 dB.................................. 0 clients
SNR 35 dB.................................. 0 clients
SNR 40 dB.................................. 0 clients
SNR 45 dB.................................. 0 clients
Nearby APs
Radar Information
RF Parameter Recommendations
Power Level.................................. 3
--More-- or (q)uit
RTS/CTS Threshold............................ 0
Fragmentation Threshold...................... 0
Antenna Pattern.............................. 0
Persistent Interference Devices
Class Type Channel DC (%%) RSSI (dBm) Last Update Time
All third party trademarks are the property of their respective owners.
(Cisco Controller) >show ap auto-rf 802.11b APCCDB.9321.62DA
AP does not have the 802.11bg radio.
(Cisco Controller) >show 802.11a
802.11a Network.................................. Enabled
11acSupport...................................... Enabled
11nSupport....................................... Enabled
802.11a Low Band........................... Enabled
802.11a Mid Band........................... Enabled
802.11a High Band.......................... Enabled
802.11a Operational Rates
802.11a 6M Rate.............................. Mandatory
802.11a 9M Rate.............................. Supported
802.11a 12M Rate............................. Mandatory
802.11a 18M Rate............................. Supported
802.11a 24M Rate............................. Mandatory
802.11a 36M Rate............................. Supported
802.11a 48M Rate............................. Supported
802.11a 54M Rate............................. Supported
802.11n MCS Settings:
MCS 0........................................ Supported
MCS 1........................................ Supported
MCS 2........................................ Supported
MCS 3........................................ Supported
MCS 4........................................ Supported
--More-- or (q)uit
MCS 5........................................ Supported
MCS 6........................................ Supported
MCS 7........................................ Supported
MCS 8........................................ Supported
MCS 9........................................ Supported
MCS 10....................................... Supported
MCS 11....................................... Supported
MCS 12....................................... Supported
MCS 13....................................... Supported
MCS 14....................................... Supported
MCS 15....................................... Supported
MCS 16....................................... Supported
MCS 17....................................... Supported
MCS 18....................................... Supported
MCS 19....................................... Supported
MCS 20....................................... Supported
MCS 21....................................... Supported
MCS 22....................................... Supported
MCS 23....................................... Supported
MCS 24....................................... Supported
MCS 25....................................... Supported
MCS 26....................................... Supported
MCS 27....................................... Supported
--More-- or (q)uit
MCS 28....................................... Supported
MCS 29....................................... Supported
MCS 30....................................... Supported
MCS 31....................................... Supported
802.11ac MCS Settings:
Nss=1: MCS 0-9 .............................. Supported
Nss=2: MCS 0-9 .............................. Supported
Nss=3: MCS 0-9 .............................. Supported
Nss=4: MCS 0-7 .............................. Supported
802.11n Status:
A-MPDU Tx:
Priority 0............................... Enabled
Priority 1............................... Enabled
Priority 2............................... Enabled
Priority 3............................... Enabled
Priority 4............................... Enabled
Priority 5............................... Enabled
Priority 6............................... Disabled
Priority 7............................... Disabled
Aggregation scheduler.................... Enabled
Frame Burst.............................. Automatic
Realtime Timeout..................... 10
Non Realtime Timeout................. 200
--More-- or (q)uit
A-MSDU Tx:
A-MSDU Max Subframes ........................ 3
A-MSDU MAX Length ........................... 8k
Rifs Rx ..................................... Enabled
Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC Status..................................... Enabled
Fragmentation Threshold.......................... 2346
RSSI Low Check................................... Disabled
--More-- or (q)uit
RSSI Threshold................................... -80
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
dfs-peakdetect................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
Voice AC - Admission control (ACM)............ Disabled
Voice Stream-Size............................. 84000
Voice Max-Streams............................. 2
Voice max RF bandwidth........................ 75
Voice reserved roaming bandwidth.............. 6
Voice CAC Method ............................. Load-Based
Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
SIP based CAC ................................ Disabled
SIP Codec Type ............................... CODEC_TYPE_G711
SIP call bandwidth ........................... 64
SIP call bandwith sample-size ................ 20
--More-- or (q)uit
Video AC:
Video AC - Admission control (ACM)............ Disabled
Video max RF bandwidth........................ 0
Video reserved roaming bandwidth.............. 0
Video load-based CAC mode..................... Disabled
Video CAC Method ............................. Static
CAC SIP-Video Configuration
Best-effort AC - Admission control (ACM)...... Disabled
Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP Radio........... 200
(Cisco Controller) >?
(Cisco Controller) >show 802.11b
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
802.11b/g 1M Rate............................ Mandatory
802.11b/g 2M Rate............................ Mandatory
802.11b/g 5.5M Rate.......................... Mandatory
802.11b/g 11M Rate........................... Mandatory
802.11g 6M Rate.............................. Supported
802.11g 9M Rate.............................. Supported
802.11g 12M Rate............................. Supported
802.11g 18M Rate............................. Supported
802.11g 24M Rate............................. Supported
802.11g 36M Rate............................. Supported
802.11g 48M Rate............................. Supported
802.11g 54M Rate............................. Supported
--More-- or (q)uit
--More-- or (q)uit
802.11n Status:
A-MPDU Tx:
A-MSDU Tx:
--More-- or (q)uit
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
--More-- or (q)uit
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
Voice CAC Method.............................. Load-Based
SIP call bandwidth: .......................... 64
SIP call bandwidth sample-size ............... 20
--More-- or (q)uit
CAC SIP-Video configuration
Maximum Number of Clients per AP................. 200
APCCDB.9321.62DA>sh controllers d 0
wifi0 Link encap:Ethernet HWaddr 48:8B:0A:14:2D:40
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:65 Memory:f8000000-f8200000
Radio Info Summary:
Radio: 2.4GHz
Carrier Set: (-E) ( TH )
Base radio MAC: 48:8B:0A:14:2D:40
Supported Channels:
1 2 3 4 5 6 7 8 9 10 11 12 13
Configured Frequency: 2412MHz Channel:1 20MHz
Number of Transmit Antennas: 4
Configured Antenna Gain(dB): 4
Legal Antenna Gain in use(dB): 4
Configured Level: 3
Configured TxPower(dBm): 10
Total Supported Power Levels:6
Allowed total powers(dBm):
16 13 10 7 4 2
Allowed per-path powers(dBm):
10 7 4 1 -2 -4
Frequency List:
Configured Frequency: 2412Mhz Channel: 1
Serving Frequency: 2412Mhz Channel: 1
Allowed Frequency: 2412Mhz(1) 2417Mhz(2) 2422Mhz(3) 2427Mhz(4) 2432Mhz(5) 2437Mhz(6) 2442Mhz(7) 2447Mhz(8) 2452Mhz(9) 2457Mhz(10) 2462Mhz(11) 2467Mhz(12) 2472Mhz(13)
Antenna config:
Antenna: RX [ a b c d ]
TX [ a b c d ]
Internal
Antenna Gain: 1. 4dBm 2. 4dBm 3. 4dBm 4. 4dBm
Rate Config:
Legacy Rates(Mbps): 1 2 5 11 6 9 12 18 24 36 48 54
HT Rates(MCS):M0 M1 M2 M3 M4 M5 M6 M7 M8 M9 M10 M11 M12 M13 M14 M15 M16 M17 M18 M19 M20 M21 M22 M23
EDCA Config:
L:Local EDCA params C:Cell EDCA params
AC Type CwMin CwMax Aifs Txop ACM
AC_BE L 4 6 3 0 0
AC_BK L 4 10 7 0 0
AC_VI L 3 4 1 94 0
AC_VO L 2 3 1 47 0
AC_BE C 4 10 3 0 0
AC_BK C 4 10 7 0 0
AC_VI C 3 4 2 94 0
AC_VO C 2 3 2 47 0
MAC Config
Beacon Interval: 100
RxSOP Sensitivity: 0
Macro Micro Steering Cfg
ANTENNA_TYPE : INT
OPMODE : Disabled
PROBE_VALIDITY_TIME(sec) : 100
SUPPRESS_RSSI_THRESH : 55
ENABLE_RSSI_THRESH : 61
PROBE_AGGR_WINDOW(msec) : 200
SUPPRESS_COUNT(#cycles) : 3
Sniffer Cfg
wcp_read wcp/Radio0.sniffer_cfg
Error: Socket read/write operation failed
DART Config
DART connector capable:CAPABLE
DART connector status :ABSENT
Associated client list:
Total Client Count:0
Radio Total_clients Legacy_clients HT/VHT20_clients HT/VHT40_clients VHT80_clients
0 0 0 0 0 0
1 0 0 0 0 0
mac radio vap aid state encr Maxrate is_wgb_wired wgb_mac_addr
WLANs and stats:
radio wlan id mac ssid state
0 0 48:8B:0A:14:2D:40 CCIW6 UP
intf TxData TxUC TxMBC TxBytes TxFail TxDcrd RxData RxUC RxMBC RxBytes RxErr UCTxRt MCTxRt stats_ago
apr0v0 0 0 0 0 0 0 0 0 0 0 0 0 0 2373083.833000
Vlan Summary:
Vlan BSSID Pri/U/M EncryPolicy Key0 Key1 Key2 Key3 iGTK SSIDs MFP
1 2D40 3 3 3 AES x128 DIS CCIW6 0
radio stats:
show per rate stats:
Video Transmission Metrics:
Media Direct Band Configuration
Unicast Video Redirect = false
Client Min Phy Rate = 0
Max Retry Percentage = 90
Dot11 Current Video Transmission Metrics:
Arrivals:0 Q-Drops:0 Tries:0 Agg:0 Success:0 Fail:0
Dot11 5-second Video Transmission Metrics:
Arrivals:0 Tries:0 Agg:0 Success:0 Fail:0
Radio-Q-Peak:0 Video-Q-Peak:0 Video-Q-Drops:0
Delay - Tot Msec:0 10/20/40/40+ Msec:0/0/0/0
Dot11 1-second Video Transmission Metrics:
Q-util:0 max-tx-time:0 p-chan:0 p-video:0 L/r:0
Radio RC stats:
Total count: 0
QBSS Load: cca_load: 0x0, rx_load: 0x0, tx_load: 0x0
APCCDB.9321.62DA>
APCCDB.9321.62DA>sh con d 1
wifi1 Link encap:Ethernet HWaddr 48:8B:0A:14:2D:40
Interrupt:102 Memory:f8400000-f8600000
Radio Info Summary:
Radio: 5.0GHz
Carrier Set: (-S) Thailand ( TH )
Supported Channels:
36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
Configured Frequency: 5180MHz Channel:36 20MHz
Configured Antenna Gain(dB): 5
Legal Antenna Gain in use(dB): 5
Configured Level: 3
Configured TxPower(dBm): 11
17 14 11 8 5 2
11 8 5 2 -1 -4
Frequency List:
Configured Frequency: 5180Mhz Channel: 36
Serving Frequency: 5180Mhz Channel: 36
Allowed Frequency: 5180Mhz(36) 5200Mhz(40) 5220Mhz(44) 5240Mhz(48) 5260Mhz(52) 5280Mhz(56) 5300Mhz(60) 5320Mhz(64) 5500Mhz(100) 5520Mhz(104) 5540Mhz(108) 5560Mhz(112) 5580Mhz(116) 5600Mhz(120) 5620Mhz(124) 5640Mhz(128) 5660Mhz(132) 5680Mhz(136) 5700Mhz(140) 5745Mhz(149) 5765Mhz(153) 5785Mhz(157) 5805Mhz(161) 5825Mhz(165)
Antenna config:
TX [ a b c d ]
Internal
Antenna Gain: 1. 5dBm 2. 5dBm 3. 5dBm 4. 5dBm
Rate Config:
Legacy Rates(Mbps): 6 9 12 18 24 36 48 54
VHT Rates: 1SS:M0-8 2SS:M0-8 3SS:M0-9 4SS:NONE
EDCA Config:
AC_BE L 4 6 3 0 0
AC_BK L 4 10 7 0 0
AC_VI L 3 4 1 94 0
AC_VO L 2 3 1 47 0
AC_BE C 4 10 3 0 0
AC_BK C 4 10 7 0 0
AC_VI C 3 4 2 94 0
AC_VO C 2 3 2 47 0
MAC Config
ANTENNA_TYPE : INT
OPMODE : Disabled
Sniffer Cfg
wcp_read wcp/Radio1.sniffer_cfg
0 0 0 0 0 0
1 0 0 0 0 0
WLANs and stats:
1 0 48:8B:0A:14:2D:4F CCIW6 UP
apr1v0 0 0 0 0 0 0 0 0 0 0 0 0 0 2373284.373000
Vlan Summary:
1 2D4F 3 3 3 AES x128 DIS CCIW6 0
radio stats:
Radio RC stats:
Total count: 0
APCCDB.9321.62DA>
APCCDB.9321.62DA>sh ver
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
Cisco AP Software, (ap3g3), [cheetah-build:/local/build/JENKINS/workspace/Nightly-Cheetah-barbados-c8_3_throttle-FC3-CCO]
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri Jul 29 04:58:20 PDT 2016
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version
APCCDB.9321.62DA uptime is 0 days, 7 hours, 41 minutes
Last reload time : Fri Jul 9 15:08:51 UTC 2021
Last reload reason : Admin Reload
cisco AIR-AP2802I-S-K9 ARMv7 Processor rev 1 (v7l) with 1030544/700092K bytes of memory.
Processor board ID FGL2502L4ZE
AP Running Image : 8.3.102.0
Primary Boot Image : 8.3.102.0
Backup Boot Image : 8.5.140.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Base ethernet MAC Address : CC:DB:93:21:62:DA
Part Number : 0-000000-00
PCA Assembly Number : 800-105672-01
PCA Revision Number : A0
PCB Serial Number : FOC24513ABU
Top Assembly Part Number : 800-105672-01
Top Assembly Serial Number : FGL2502L4ZE
Top Revision Number : A0
Product/Model Number : AIR-AP2802I-S-K9
APCCDB.9321.62DA>
APCCDB.9321.62DA#sh logging
System logging:
Jul 9 18:42:18 brain: CDP PoE negotiation FAILED !!
Jul 9 18:42:18 brain: LLDP PoE negotiation START
Jul 9 18:42:50 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:42:50 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:42:55 brain: Restart POE negotiation
Jul 9 18:43:00 brain: CDP PoE negotiation START
Jul 9 18:44:00 brain: CDP PoE negotiation FAILED !!
Jul 9 18:44:00 brain: LLDP PoE negotiation START
Jul 9 18:44:32 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:44:32 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:44:37 brain: Restart POE negotiation
Jul 9 18:44:42 brain: CDP PoE negotiation START
Jul 9 18:45:42 brain: CDP PoE negotiation FAILED !!
Jul 9 18:45:42 brain: LLDP PoE negotiation START
Jul 9 18:46:14 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:46:14 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:46:19 brain: Restart POE negotiation
Jul 9 18:46:24 brain: CDP PoE negotiation START
Jul 9 18:47:24 brain: CDP PoE negotiation FAILED !!
Jul 9 18:47:24 brain: LLDP PoE negotiation START
Jul 9 18:47:56 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:47:56 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:48:01 brain: Restart POE negotiation
Jul 9 18:48:06 brain: CDP PoE negotiation START
Jul 9 18:49:06 brain: CDP PoE negotiation FAILED !!
Jul 9 18:49:06 brain: LLDP PoE negotiation START
Jul 9 18:49:39 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:49:39 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:49:44 brain: Restart POE negotiation
Jul 9 18:49:49 brain: CDP PoE negotiation START
Jul 9 18:50:48 brain: CDP PoE negotiation FAILED !!
Jul 9 18:50:48 brain: LLDP PoE negotiation START
Jul 9 18:51:21 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:51:21 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:51:26 brain: Restart POE negotiation
Jul 9 18:51:31 brain: CDP PoE negotiation START
Jul 9 18:52:31 brain: CDP PoE negotiation FAILED !!
Jul 9 18:52:31 brain: LLDP PoE negotiation START
Jul 9 18:53:03 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:53:03 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:53:08 brain: Restart POE negotiation
Jul 9 18:53:13 brain: CDP PoE negotiation START
Jul 9 18:54:13 brain: CDP PoE negotiation FAILED !!
Jul 9 18:54:13 brain: LLDP PoE negotiation START
Jul 9 18:54:45 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:54:45 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:54:50 brain: Restart POE negotiation
Jul 9 18:54:55 brain: CDP PoE negotiation START
Jul 9 18:55:55 brain: CDP PoE negotiation FAILED !!
Jul 9 18:55:55 brain: LLDP PoE negotiation START
Jul 9 18:56:27 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:56:27 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:56:32 brain: Restart POE negotiation
Jul 9 18:56:37 brain: CDP PoE negotiation START
Jul 9 18:57:38 brain: CDP PoE negotiation FAILED !!
Jul 9 18:57:38 brain: LLDP PoE negotiation START
Jul 9 18:58:10 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:58:10 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:58:15 brain: Restart POE negotiation
Jul 9 18:58:20 brain: CDP PoE negotiation START
Jul 9 18:59:20 brain: CDP PoE negotiation FAILED !!
Jul 9 18:59:20 brain: LLDP PoE negotiation START
Jul 9 18:59:51 brain: LLDP PoE negotiation FAILED !!
Jul 9 18:59:51 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 18:59:56 brain: Restart POE negotiation
Jul 9 19:00:02 brain: CDP PoE negotiation START
Jul 9 19:01:01 brain: CDP PoE negotiation FAILED !!
Jul 9 19:01:01 brain: LLDP PoE negotiation START
Jul 9 19:01:34 brain: LLDP PoE negotiation FAILED !!
Jul 9 19:01:34 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 19:01:39 brain: Restart POE negotiation
Jul 9 19:01:44 brain: CDP PoE negotiation START
Jul 9 19:02:44 brain: CDP PoE negotiation FAILED !!
Jul 9 19:02:44 brain: LLDP PoE negotiation START
Jul 9 19:03:16 brain: LLDP PoE negotiation FAILED !!
Jul 9 19:03:16 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 19:03:21 brain: Restart POE negotiation
Jul 9 19:03:26 brain: CDP PoE negotiation START
Jul 9 19:04:26 brain: CDP PoE negotiation FAILED !!
Jul 9 19:04:26 brain: LLDP PoE negotiation START
Jul 9 19:04:58 brain: LLDP PoE negotiation FAILED !!
Jul 9 19:04:58 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 19:05:03 brain: Restart POE negotiation
Jul 9 19:05:08 brain: CDP PoE negotiation START
Jul 9 19:06:08 brain: CDP PoE negotiation FAILED !!
Jul 9 19:06:08 brain: LLDP PoE negotiation START
Jul 9 19:06:41 brain: LLDP PoE negotiation FAILED !!
Jul 9 19:06:41 bra
@Rps-Cheers please kindly help thank you.
07-10-2021 09:01 PM
APCCDB.9321.62DA should have problems in power supply negotiation.
Jul 9 19:04:26 brain: CDP PoE negotiation FAILED !! Jul 9 19:04:26 brain: LLDP PoE negotiation START Jul 9 19:04:58 brain: LLDP PoE negotiation FAILED !! Jul 9 19:04:58 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Note: If the AP2800 and AP 3800 are powered from an 802.3af power source the LED will cycle though the colors and the radios will be disabled.
Can this AP use other interfaces of the switch or replace other switches for power supply? Or use a power injector?
You can use the "show ap config general <ap-name>" command to check the basic situation of the AP.
eg:
Power Type/Mode.................................. Power injector / Full Power <------------ Number Of Slots.................................. 2
07-10-2021 09:41 PM
@Rps-Cheers wrote:Jul 9 19:04:26 brain: CDP PoE negotiation FAILED !! Jul 9 19:04:26 brain: LLDP PoE negotiation START Jul 9 19:04:58 brain: LLDP PoE negotiation FAILED !! Jul 9 19:04:58 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Oh, I know what this is.
This is a very well-known bug affecting the OS of the 2800/3800/4800.
Easy enough fix -- Upgrade the firmware to the latest train. So if the controller is running 8.3.102.0 then upgrade to whatever is latest 8.3.X.X will fix this bug.
07-10-2021 09:49 PM
really? I retrieved a bug similar to ap1562, but the bug status has been terminated. Do you know the bug id of the bug you mentioned?
07-10-2021 11:01 PM
Very similar to CSCvs15528.
07-09-2021 08:25 AM
Replaced radius joined the WLC ? and configured SSID ?
07-09-2021 06:28 PM
Is the Out-Of-Box RF profile enabled? If so you'll need to enable the radios on the AP.
07-09-2021 06:34 PM
Which radio(s) is/are down? Is it the 5.0 Ghz?
If it is, it could be the WLC is configured with multiple- and conflicting Regulatory Domain.
07-09-2021 07:42 PM
this is down.
07-09-2021 08:12 PM
07-09-2021 08:15 PM
I will have try and lets you know. maybe need to manual disconnect and connect again on POE injector.
07-11-2021 04:48 PM
@Rps-Cheers @Leo Laohoo @balaji.bandi @craig.beck the problem came from power injector I have try to unplug and plug again It come to work. thank all
07-11-2021 06:43 PM
It's very nice to problem resovled~
