Cisco air 2802I joined to WLC Radio was down
boylogin
some body help I have change new AP with same model in the network when joined to the WLC2504 everything look fine but the radio Oper was Down also cleanAir oper status Down
18 Replies 18
Only 10 APs, so it very easy to find out.
Go to 802.11a/n/ac Radios > Detail.  Identify which AP has the radio down.
Go back to Monitor > All APs > Detail and look at for the same AP.   Go to the Interface tab.  Look at the bottom right-hand corner of the screen under Regulatory Domain.  What does it say?
boylogin
I found this any one have idea.
Jul 9 23:35:49 kernel: [*07/09/2021 23:35:49.0000] CAPWAP State: DTLS Setup
Jul 9 23:35:50 kernel: [*07/09/2021 23:35:50.2171] CAPWAP State: Join
Jul 9 23:35:50 kernel: [*07/09/2021 23:35:50.2185] Sending Join request to 192.168.99.11 through port 5248
Jul 9 23:35:54 kernel: [*07/09/2021 23:35:54.8948] Join Response from 192.168.99.11
Jul 9 23:35:54 kernel: [*07/09/2021 23:35:54.8949] CAPWAP State: Image Data
Jul 9 23:35:54 kernel: [*07/09/2021 23:35:54.8950] CAPWAP State: Configure
Jul 9 23:35:55 kernel: [*07/09/2021 23:35:55.6775] Radio0 not started, not enough POE power
Jul 9 23:35:56 kernel: [*07/09/2021 23:35:56.5966] Radio1 not started, not enough POE power
Jul 9 23:35:57 syslog: +ifconfig wired0 promisc
Jul 9 23:35:57 kernel: [*07/09/2021 23:35:57.6525] Radio0 not started, not enough POE power
Jul 9 23:35:57 kernel: [*07/09/2021 23:35:57.6528] Radio1 not started, not enough POE power
Jul 9 23:35:57 kernel: [*07/09/2021 23:35:57.6532] Radio0 not started, not enough POE power
Jul 9 23:35:57 kernel: [*07/09/2021 23:35:57.6597] Radio1 not started, not enough POE power
Jul 9 23:35:57 kernel: [*07/09/2021 23:35:57.6649] Radio0 not started, not enough POE power
Jul 9 23:35:58 kernel: [*07/09/2021 23:35:58.3453] Radio1 not started, not enough POE power
Jul 9 23:35:59 kernel: [*07/09/2021 23:35:59.2782] CAPWAP State: Run
Jul 9 23:35:59 kernel: [*07/09/2021 23:35:59.3279] AP has joined controller WLC-2504
Jul 9 23:35:59 syslog: Password for 'admin' changed
Jul 9 23:35:59 kernel: [*07/09/2021 23:35:59.4081] Password for 'admin' changed
Jul 9 23:36:48 brain: CDP PoE negotiation FAILED !!
Jul 9 23:36:48 brain: LLDP PoE negotiation START
Jul 9 23:36:56 syslog: +ifconfig wired0 promisc
Jul 9 23:37:20 brain: LLDP PoE negotiation FAILED !!
Jul 9 23:37:20 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 23:37:24 syslog: +ifconfig wired0 promisc
Jul 9 23:37:25 brain: Restart POE negotiation
Jul 9 23:37:30 brain: CDP PoE negotiation START
Jul 9 23:38:40 brain: CDP PoE negotiation FAILED !!
Jul 9 23:38:40 brain: LLDP PoE negotiation START
Jul 9 23:39:12 brain: LLDP PoE negotiation FAILED !!
Jul 9 23:39:12 brain: Power mode: Degraded/Reduced Power, power_detection: DC_adapter(FALSE), 802.3AF_POE(TRUE)
Jul 9 23:39:17 brain: Restart POE negotiation
Jul 9 23:39:22 brain: CDP PoE negotiation START
Jul 9 23:40:22 brain: CDP PoE negotiation FAILED !!
Jul 9 23:40:22 brain: LLDP PoE negotiation START
Jul 9 23:40:54 brain: LLDP PoE negotiation FAILED !!
Yes, this is a relatively obvious phenomenon. We can see that the PoE of the AP cannot be negotiated, so Radio0 and Radio1 cannot be up, so I suggest cross-testing or use the power injector to supply power to see if the AP is working properly.
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
is the AP connecting to the switch, check on the switch is the AP getting enough power?
BB
