Cisco AIR-AP1231G-A-K9 middle light flashes
Rita G.
I have a Cisco AIR-AP1231G-A-K9 that used to work, but now it’s not, and the middle green light flashes (about 3x per second).
I have no idea what to do. Can someone please help me fix it?
14 Replies 14
 According to the 1200 manual, this indicates as follow:
 Middle Led indicates AP status:
The status LED signals operational status. Green indicates that the access point is associated with
at least one wireless client. Blinking green indicates that the access point is operating normally but
is not associated with any wireless devices.
When you are close to this Access Points, do you see SSIDs ?  If does, are you able to connect ?
If does not, have you reboot the AP ?
-If I helped you somehow, please, rate it as useful.-
"When you are close to this Access Points, do you see SSIDs ?  If does, are you able to connect ?
If does not, have you reboot the AP ?"
thank you for replying . .
No sign of it on phone or laptop.
Not able to connect.
reboot does nothing.
Rasika Nayanajith
Is it possible to post output what you see from AP console (if you have access to it)
Rasika
Thanks . .
I have no access to it.
Oh PLEEEEEEZE help me!
I really need my wifi back again!
A few years ago I worked on one of these with an old windows XP computer and a 9-pin to rj45 cable, but I can’t remember how I connected; that was a few years ago.
I’ll take a look through the basement to see if I can find the XP computer . . hopefully it still works. I found the blue 9-pin to rj45 cable.
"Is it possible to post output what you see from AP console (if you have access to it)"
Can someone please tell me how?
Here is the manual:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4-25d-JA/Configuration/guide/cg_12_4_25d_JA/scg12-4-25d-JA-chap4-first.html#76570
There is also a slim possibility that the AP has a defect. The console connection might show it.
ok I am able to connect with old XP computer using PuTTY, but I don't know what to enter.
If someone could give me a command to enter into the console, then perhaps I could post an output.
Simply power cycle the AP & see what you get in console output. No need to issue any specific command
Rasika
*Mar  3 11:35:09.369: %LINK-3-UPDOWN: Interface BVI1, changed state to upXmodem file system is available.
flashfs[0]: 149 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4963840
flashfs[0]: Bytes available: 2777600
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:12:43:c3:ac:48
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuint boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1200-k9w7-mx.123-8.JEA1/c1200-k9w7-mx.123-8.JEA1"...################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w7-mx.123-8.JEA1/c1200-k9w7-mx.123-8.JEA1" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 15-Jan-07 23:17 by kellythw
Image text-base: 0x00003000, data-base: 0x006979C0
Initializing flashfs...
flashfs[1]: 149 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4963840
flashfs[1]: Bytes available: 2777600
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1231G-A-K9     (PowerPC405GP) processor (revision B0) with 15138K/1236K bytes of memory.
Processor board ID FOC08421XQ4
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:43:C3:AC:48
Part Number                          : 73-8704-07
PCA Assembly Number                  : 800-23211-08
PCA Revision Number                  : A0
PCB Serial Number                    : FOC08421XQ4
Top Assembly Part Number             : 800-23304-07
Top Assembly Serial Number           : FTX0845R0YH
Top Revision Number                  : B0
Product/Model Number                 : AIR-AP1231G-A-K9
Press RETURN to get started!
*Mar  1 00:00:04.259: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:05.464: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.551: %SYS-6-LOGGERSTART: Logger process started
*Mar  1 00:00:07.553: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.553: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:00:26.643: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:26.716: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:26.716: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:27.642: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:27.668: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:38.573: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:39.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar  1 00:00:58.676: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:00:59.676: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:08.573: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:01:09.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
*Mar  1 00:01:28.678: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:01:29.678: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
*Mar  1 00:01:38.573: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:01:39.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
*Mar  1 00:02:03.680: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:02:04.680: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
*Mar  1 00:02:08.573: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:02:09.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
This looks like an issue with the LAN interface. Can you replace the LAN cable please or the switchport?
thank you(s) for replies; i think we're getting somewhere!
ok, i connected it to it's wired LAN switch and now it has 2 (out of 3) blinking green lights, but SSID does not show up on phone or laptop.
Can you reboot it now again and please post the output?
