Cisco AIR-AP1252AG-A-K9 Access Point
mohammed-amjad
I have AIR-AP1252AG-A-K9 Access Point and AIR-ANT5135D-R Antenna but when i connect this antenna 5GHZ is not showing in my computer only showing 2GHZ.  Please help me in this issue
22 Replies 22
Nicolas Darchis
1) How are you powering the access point ? PoE ? Power supply ? If power supply, how many volts does it indicate on it ?
2) Can you show your configuration (show run) ?
3) Did you plug the antenna on the correct side of the access point ? (it should mention 5ghz, antenna A)
Nicolas
A: I am powering the access point through Power supply and it indicates 56V 0.8A
ap#show run
Building configuration...
Current configuration : 2025 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$.Tdg$les2CZTVM8J6et4b2ktSj1
no aaa new-model
dot11 ssid 1252
authentication open
guest-mode
power inline negotiation prestandard source
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 603D777BD049 transmit-key
encryption mode wep mandatory
ssid 1252
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption key 1 size 40bit 7 F522911622F5 transmit-key
ssid 1252
antenna gain 10
dfs band 3 block
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel 5200
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.0.0.1 255.0.0.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
A: Yes I have plugged the 3 Antennas in 5GHZ antennas side
ap#
Boot the AP.  Post everything during bootup including the "sh log" and "sh version".
Please find the attachments of show log and show version and this access is converted from LAP to AP.
All looks ok (by the way, the fact that your ssid is WEP prevents to use 802.11n which is a shame with an AP allowing 802.11n :-) )
Can you say which client wireless adapter you have ? The exact model ?
Nicolas
I am using Broadcom 802.11g Network Adapter
So your client is not capable of 5ghz :-)
The AP is transmitting fine on the 5ghz but it's the client who just cannot receive it.
Thanks for your reply and just I need to know which client adapter will work for this access point.
Any that is capable of 5ghz ? :-)
Usually they put a "a" in the name. Yours only does 802.11g (2.4ghz).
Intel writes "3945 ABG" or "ABGN" if it does 11n as well.
Nicolas
Please find the attachments. I brought Linksys WUSB600N Wireless Adapter to support 5GHZ and it works fine but giving me an error when I go little far from the access point I am loosing the signal and I am getting week signal. (What if I use AIR-ANT5195P-R antenna and if I use AIR-5135D-R antenna)
I am getting these errors: Interface Dot11Radio1, Deauthenticating Station 0025.9c9a.fe37 Reason: Sending station has left the BSS
How to fix this problem?
What distance are we talking about ?
The distance is 2-3 meters far only.
lonnylegrand
I have this same access point, currently I can only configure it to with WPA - TKIP. How do I upgrade this to run WPA-2 AES encryption. I'm on site and would like to upgrade not just this one but all the others that I have as well. Please help. My current software version is 12.4(10b).JA3
Lonny
Lonny,
     This is a very old thread, you really should open a new one.
That being said, the 1252 supports WPA2/AES in that version of code
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
