01-15-2011 10:13 PM - edited 07-03-2021 07:40 PM
I have AIR-AP1252AG-A-K9 Access Point and AIR-ANT5135D-R Antenna but when i connect this antenna 5GHZ is not showing in my computer only showing 2GHZ. Please help me in this issue
03-13-2013 01:06 PM
Is that the WPAv2 in the drop down menu setting.... I saw WPA, WPAv1 and WPAv2, did not equate that too WPA-2..... Please tell me its one in the same so I can get started with wiping the embarrasment away....
03-13-2013 01:08 PM
yes, yes it is.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
03-13-2013 01:13 PM
So no need to upgrade the software. Is there an upgrade for the 1252 that I might consider and what are the advantages to the change if you dont mind.... Thanks again for your reply...
03-13-2013 01:21 PM
best bet is to read the release notes, see what bug fixes are out there. but i'm a big believer in if it ain't broke don't fix it.
HTH,
Steve
03-13-2013 01:22 PM
Couldnt agree with you more on that. Thanks a million...
03-13-2013 01:45 PM
Hey Steve, would the same apply to an air-ap1131abg, the WPAv2 is WPA-2...
03-13-2013 01:47 PM
yes, will be true for any AP that supports WPAv2
03-13-2013 01:07 PM
Also, I see a Globe and Anchor for your icon....... Army Tomb Guard here. Thank you kindly for your service Marine
