Cisco Aironet Sensor 1800S replacement
Hi everyone,
What equipment can replace the 1800s sensor, for use through DNA Center? because this hardware went into EoS??
Best Regards
2 Accepted Solutions
 The replacement is informed on the EoL announcement. For this specific device Cisco did not indicate a replacement. Either they will deactivate this service or they will come up with a new solution.  If I had to guess, I would say the might transfer this functionality to standard Access Points.
 I started a project with Sensor few month ago but honestly I did not get the result I was expecting.
Rasika Nayanajith
My guess is Cisco will discontinue these sensors without any replacement. You require DNAC to use these sensors and for many customers maintaining a DNAC is very expensive solution
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Leo Laohoo
I believe the 1800S will not have any replacement.  There was talk of one before 2019 but did not materialize because the 1800S was a sales and engineering flop.  Other vendors are able to market theirs cheaper, better performance and can do more.   The mandatory requirement for DNAC (and associated "cloud" related products) made it a tough pill swallow.
Users want something easy to use, easy to deploy, easy to manage without burning through several year's worth of hard-to-get budget with DNAC & Cisco Catalyst Cloud, etc.
Would you please to point available solutions from other vendors - I mean wireless probes?
