Cisco C9800-L WLC is not being synchronised with NTP
King_1988
Cisco C9800-L WLC is not being synchronized with NTP server. What could be the issue?
5 Replies 5
JPavonM
Which interface are you using for NTP communications? Have you checked there is no firewall or that traffic is allowed in the firewall policies?
Could you share your NTP config please?
-Jesus
*** Please Rate Helpful Responses ***
Hi Pavon,
There is no Firewall. Other devices are being synchronized successfully. I have attached screenshot of my GUI of 9800-L.
I have only added NTP server in 'Time' tab. Is there any other configuration needed?
Remove it and add it again... look at the vrf as it depends on how you have your management configured. Either way, add it again and or try an external NTP for testing.
-Scott
This works fine for me:
ntp source GigabitEthernet0
ntp server vrf Mgmt-intf <server-ip>
Verify it in CLI
9800#show run | in ntp
9800#show ntp association
9800#show ntp status
Rasika
