cisco-capwap-controller
*mcListen: [PA]mc_task.c:4279 Time sync failure for Handoff Complete on MC, dropping the packet. Client MAC: xx:xx:xx:xx:xx:xx
Ladies and Gentelmen,
What is the source of this issue?how to resolve?
8 Replies 8
Leo Laohoo
Nothing to see here.  Only one line of error message and a question with no other relevant information.
Nothing to see here.  Move along.
check this post & see it matches your scenario
https://community.cisco.com/t5/wireless/wlc-5508-mm-3-notify-error-mac/td-p/3371658
Rasika
*** Pls rate all useful responses ***
but i'm facing this with many employees which are using mobile phone and they don't have idea hoe to make release ip and reconnect and some of them are not complaining, and there are many messages like these so i'm try to understand where the problem
The simplest way to release and renew IP on any mobile device is to forget and then re-join the SSID.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Rich R
Is there a fault?
What is the detailed description of the fault?
Have you reproduced the fault?
Have you run a debug on an affected client MAC?
Have you run that debug output through the debug analyzer?
What controller model?
Running what version of software?
Using what model of AP (precise model number)?
AireOS produces thousands of meaningless messages which may (or not) be of some interest to the developers but have no impact on normal operation.  If you're not seeing an actual fault which is proved to be related to this message then ignore it.  Focus on the basics of troubleshooting all problems.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.135.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console                                 2.2
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
controller model 5508
3702 or 3602
So your software version is out of date.  Start off by updating the code to eliminate hundreds of known bugs which have been fixed since then.
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc10
Still no detailed description of the problem or answers to the other questions so really not possible to offer any further advice.
- Define the problem clearly
- Reproduce the problem yourself
- Collect debugs for an affected client
- Analyse the results.
- If you still can't solve the problem (and your software is up to date) then open a case with Cisco TAC so they can talk you through it step by step.  They are still going to ask you all the same questions though.
