cisco LAP 2602 can not join Virtual WLC
Ali mosbah Abdo
dear all,
i just install Virtual WLC and i remove WLC 2504 , i install & configured it , but LAP can not join. it was work fine with WLC 2504.
i used the same network topology with the old WLC.
i receive this error logs.
*spamApTask4: Feb 04 06:01:30.082: <<<<  Start of CAPWAP Packet  >>>>
*spamApTask4: Feb 04 06:01:30.082: CAPWAP Control mesg Recd from 10.192.200.93, Port 26711
*spamApTask4: Feb 04 06:01:30.082:              HLEN 4,   Radio ID 0,    WBID 1
*spamApTask4: Feb 04 06:01:30.082:              Msg Type   :   CAPWAP_DISCOVERY_REQUEST
*spamApTask4: Feb 04 06:01:30.082:              Msg Length : 155
*spamApTask4: Feb 04 06:01:30.082:              Msg SeqNum : 0
*spamApTask4: Feb 04 06:01:30.082:       Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask4: Feb 04 06:01:30.082:              Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamApTask4: Feb 04 06:01:30.082:       Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask4: Feb 04 06:01:30.083:              Vendor Identifier      : 0x00409600
*spamApTask4: Feb 04 06:01:30.083:              WTP_SERIAL_NUMBER : AIR-CAP2602E-I-K9
*spamApTask4: Feb 04 06:01:30.083:       Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask4: Feb 04 06:01:30.083:              Maximum Radios Supported  : 2
*spamApTask4: Feb 04 06:01:30.083:              Radios in Use             : 2
*spamApTask4: Feb 04 06:01:30.083:              Encryption Capabilities   : 0x00 0x01
*spamApTask4: Feb 04 06:01:30.083:       Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask4: Feb 04 06:01:30.083:              WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask4: Feb 04 06:01:30.083:       Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask4: Feb 04 06:01:30.083:              WTP Mac Type  : SPLIT_MAC
*spamApTask4: Feb 04 06:01:30.083:       Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
        IE            :   UNKNOWN IE 207
*spamApTask4: Feb 04 06:01:30.083:      IE Length     :   4
*spamApTask4: Feb 04 06:01:30.083:      Decode routine not available, Printing Hex Dump
*spamApTask4: Feb 04 06:01:30.083: 00000000: 03 00 00 01                                       ....
*spamApTask4: Feb 04 06:01:30.083:       Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 12
        IE            :   RAD_NAME_PAYLOAD
*spamApTask4: Feb 04 06:01:30.083:      IE Length     :   6
*spamApTask4: Feb 04 06:01:30.083:      Rad  Name     :
*spamApTask4: Feb 04 06:01:30.083: CEO_AP
*spamApTask4: Feb 04 06:01:30.083: <<<<  End of CAPWAP Packet  >>>>
*spamApTask4: Feb 04 06:01:30.083: dc:a5:f4:8c:ff:30 Discovery Request from 10.192.200.93:26711
*spamApTask4: Feb 04 06:01:30.083: dc:a5:f4:8c:ff:30 ApModel: AIR-CAP2602E-I-K9
*spamApTask4: Feb 04 06:01:30.083: dc:a5:f4:8c:ff:30 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask4: Feb 04 06:01:30.083: apModel: AIR-CAP2602E-I-K9
*spamApTask4: Feb 04 06:01:30.083: apType = 26 apModel: AIR-CAP2602E-I-K9
*spamApTask4: Feb 04 06:01:30.083: apType: Ox1a bundleApImageVer: 8.0.110.0
*spamApTask4: Feb 04 06:01:30.083: version:8 release:0 maint:110 build:0
*spamApTask4: Feb 04 06:01:30.083: dc:a5:f4:8c:ff:30 Discovery Response sent to 10.192.200.93 port 26711
*spamApTask4: Feb 04 06:01:30.083: dc:a5:f4:8c:ff:30 Discovery Response sent to 10.192.200.93:26711
Please any help.
You may need to put the AP in flexconnect mode before you move it.  Is the WLC 2504 at least 7.4?
6 Replies 6
shh5455
Level 3
Level 3
Is the AP in flexconnect mode?  Does the AP have at least version 7.4 on it?  These are requirements.
Dear shh5455
in local mode because they was connected to wlc 2504, but if they joint i will change them to Flecconnect mode.
the vWLC is v 8.0.110
dear
yes  the wlc  2504  is 8.0.110 but because its damaged i replaced it with  new vWLC v 8.0.110.
also i can not put the LAP in flexconnect until its joint.
Can you pull the logs off of the AP when it's trying to join?
Thank you dear
its joint now.
i just add command in the cWLC for flexconnect
BR
