cisco mobilty issue
Michele Toblini
Level 2
Level 2
I got an issue between one of my branches where the mobility tunnel goes down suddenly.
The release is 8.2.166.0 and the workaround is delete the ssid and create it again.
I noticed that when this happen the mping doesn't work. Maybe a bug?
patoberli
Does the normal ping work if the mping doesn't? Maybe there are short outages or network overloads causing this?
Then there was also this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva66176 fixed in 8.2.170.0.
the ping works find when the mping doesn't. I read the bug but i don't understand what "AP drop of from Network due to large set of Mobility groups in down/down" means.
I got just 2 mobility tunnel over my 2 hub wlcs..
What they probably mean in the bug description, the APs will be dropped from the network if that bug happens in some variations. So I would upgrade in any case.
Haydn Andrews
Sounds like a bug.
The TAC recommended build is for the 8.2.x train is 8.2.170.0
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Suggest upgrading to one of the recommended releases
*****Help out other by using the rating system and marking answered questions as "Answered"*****
