Cisco Virtual Wireless Controller Web GUI or management very slow
mohranj396968
Community Member
hi
Cisco Virtual Wireless Controller Web GUI or management very slow to login
im test with firefox.chrome.brave.edge browser and no solve
show sysinfo
Manufacturer's Name. Cisco Systems Inc.
Product Name. Cisco Controller
Product Version... 8.3.122.0
RTOS Version. 8.3.122.0
Bootloader Version.. 8.3.15.96
Emergency Image Version. 8.3.122.0
SNMP Protocols
v1:Disabled v2c:Enabled v3:Enabled
Syslog
Disabled
HTTP Mode
Enabled
HTTPS Mode
Disabled
New Telnet Sessions Allowed
Yes
New SSH Sessions Allowed
Yes
Management via Wireless
Disabled
9 Replies 9
Mark Elsen
 - Check performance stats on the hypervisor  ,make sure the the WLC-VM has sufficient  resources such as CPU and Memory , also look into : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html , advising to use latest release possible since AireOS is getting old ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
mohranj396968
Community Member
no performance in esxi panel
cpu :2*2
ram:10
for 57 access point
 - As stated  consider 8.3.122.0  outdated , check https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
mohranj396968
Community Member
This problem did not exist until a few days ago
And my Accesspoint are old models, can't I update the controller??
- Then reboot the controller when possible and check if that can help. Also
look into modernizing your wireless infrastructure ,
M.
       Beauty and terror
      Just keep going
       No feeling is final
mohranj396968
Community Member
Yes, I restarted, but it didn't help
Due to the high cost, we are currently unable to replace the equipment
- I am out of words, besides other replies urgent business needs must be
handled by TAC (cisco support), but they won't be able to help much because
of outdated software being used to start with,
M.
       Beauty and terror
      Just keep going
       No feeling is final
balaji.bandi
check this thread may help you (virtual or physical same issue)
https://community.cisco.com/t5/wireless/its-very-slow-to-access-wlc5508-by-gui/td-p/3867574
Another Option is, just create another VM with the same vWLC version to see is that works as expected and move any test AP to new  vWLC
BB
Rich R
Like @Mark Elsen has already said 8.3.122.0 is VERY old so you could be affected by hundreds of different bugs.
@balaji.bandi has highlighted the other most likely cause (https redirection) but it be would be surprising if that suddenly appeared now without you changing anything.  If you changed something - then change it back!  Either way - if you're using https try switching to http for GUI and see if that makes a difference.  Obviously your data (including username/password on login) will then not be encrypted so you'll need to apply appropriate mitigation for that.
You have not mentioned your AP models so consult the compatibility matrix link below for which versions you can run.
At the very least you should update to the latest 8.3.150.0 which will support all the same APs as 8.3.122.0.  Be aware of the field notices linked below as you might need to change date on WLC for APs to be able to download new image (not fixed in 8.3).
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
