Cisco wireless and apple ios devices
netdood
My apple devices at work running ios 6 have a problem with streaming video like youtube.  The problem is it won't play the video at all, and will either just have a spinning loading icon or "play button" icon crossed out.  The same iphone device will play youtube videos fine at home on a Cisco M10 Valet home wireless router.  One ipad2 with older ios5 plays streaming video fine at work.  Macbooks and windows laptops also play streaming video over wireless fine.
Does anybody know how to fix this?  Has anybody got streaming video to apple devices on ios 6 working?
Here is my environment,
WLC 5508 version 7.3
Mix of 3502, 3602, 1142 APs.  50 APs deployed around internal LAN on campus.
ssid settings,
layer 2 - wpa+wpa2, wpa2 policy, wpa2 encryption AES, auth key mgmt 802.1x
no layer 3 security
qos - platinum
About 100 users
Let me know if there are any other settings to look at or try.
I've also tried the fast transition feature which seemed to improve roaming but not the streaming video issue.
Trent Hurt
I have seen this on 7.2 code as well. It seems iphone's may not do TSPEC per this link...
https://discussions.apple.com/thread/4327729?start=0&tstart=0
Found this in old 4.x wlc doc...
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40ccfg.html
"For WMM clients that do not support traffic specifications (TSPEC), disable ACM to allow for proper QoS mapping.For WMM clients that do not support traffic specifications (TSPEC), disable ACM to allow for proper QoS mapping.
Try to disable video call admission control on the wlc...
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ccfg.html#wp1922543
12 Replies 12
Trent Hurt
Leo Laohoo
7.4.100.X code has some enhancements to Apple Bonjour.  The next firmware release, 7.5.X.X, will incorporate stage 2 enhancements.
Wireless LAN Apple Bonjour Deployment Guide
Stage 2 enhancements, can you expand on that? Like filtering the bonjour advertisements to certain aps
I don't because I read this on the Release Notes for the 7.5.X.X.
7.5.X.X will be released in the next few months.  I think 7.5.X.X is an interim version before 8.0.X.X comes out.
Trent Hurt
http://mrncciew.files.wordpress.com/2013/02/wlc-74-01.png
Thanks twhurt001  disabling video CAC fixed the video streaming problem for ios 6 devices!   Is there a more authoratative website with the information you posted on http://mrncciew.files.wordpress.com/2013/02/wlc-74-01.png  ?
I've been searching for where the ios 6 CAC bug is documented.
I'll also have to test ios 5 devices again when I get a chance.
VIP endorsed! Glad to see you monitor the forums my friend!
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Unfortunately I haven't been able to get anything official other than the stuff I have posted.
Hi  Tim,
Here is the bug information you are looking for CSCud67358
Rasika
Rasika,
Do you have the bug details ? Its not showing anything ..
Hi George,
Here is the detail I got when I search bugID CSCud67358 in the bug toolkit
Symptom:
Apple clients running iOS 6.0.1 may experience degraded throughput when
attempting to download media rich content such as video.
Apple clients running iOS 5.x or earlier do not experience the issue under
identical conditions.
Apple support has observed and analyzed the issue, and has confirmed non
compliant CAC behavior with iOS 6.0.1 software. Apple intends to correct the
issue in forthcoming firmware updates.
This release note will be updated with code fix specifics when available.
Conditions:
Apple iOS 6.0.1 client connected to Unified Access Point at 802.11N data rates
with Video Call Admission Control (CAC) enabled.
Workaround:
Disable 802.11N support or disable Video Call Admission Control (CAC).
HTH.
Rasika
