Cisco Wireless control system
elliot_adlerson
hey people ,
as far as we know the Cisco WCS is EOS AND EOL  and same goes for adobe flash player which is not supported anymore  and WCS requiring Adobe flash player to see data and so on .
what is the solution for such case is there any other services than i can control radio waves and control them how far can they go ,or is there any alternative to Cisco wcs ?
Your help are highly appreciated, thank you guys .
Leo Laohoo
The replacement of WCS is Cisco Prime Infrastructure.
PI is going to be replaced with the super-expensive DNA Centre (if-and-when the BU can get the stability addressed).
DNA Centre is aimed primarily at very large organization with money to spend.  There are two major components that makes DNAC is unaffordable:
  1. Price of the hardware
  2. Price of the subscription license
On the other hand, Cisco is giving away free DNAC (DN2-HW-APL) for FREE.
balaji.bandi
You need to use WLC Controller here. WCS ended More than a decade now.
https://www.cisco.com/c/en/us/products/wireless/wireless-lan-controller/index.html#~benefits
BB
Mark Elsen
 - You may consider cisco Prime instead , is more modern and or does no longer depend on the Flash  requirements.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
