Cisco WLC CLI AP AP-GROUP ASSIGN
Aydin Ehtibarov
Level 2
Level 2
Dear colleagues,
i am trying to change AP group name for 180 access-points. I would like to do this over CLI . But the issue is every time i past the config line WLC request confirmation as below:
(Cisco Controller) >config ap group-name Apartment-Rental AP-APP-203_1
Changing the AP's group name will cause the AP to reboot.
Are you sure you want to continue? (y/n)
as the result i cannot past all 180 lines at ones to cli and finish the task
is there any "noconfirm" option to use with this command ?
thank you in advance!
   There´s no "no confirm" but you can add Yes and go ahead. Are you using a spreadsheet?
jagan.chowdam
In the past, I used Excel and added "y" in a new row for all commands and it worked.
CJ
Haydn Andrews
Been caught out by this before.
I used subline text to insert a line under every "config ap ..." and added "y" as the value on that line.
Then it works when you paste it into the CLI.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Rich R
Just make sure you're on latest AireOS.  There was a regression bug we found in earlier 8.8 that when you tried to paste in a lot of commands with prompts like that the buffer choked so you could only do a few lines at a time.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn47094
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
