Wlc 9800 won't push DNS/domain changs to some AIR-CAP2702I-A-K9 AP.
dmooreami
Level 3
Level 3
We have a WLC-9800  controlling  AIR-CAP2702I-A-K9. we setup up AP's Ipconfig section  original DNS to exp 1.1.1.1/example.com.
We now need to change it to 2.2.2.2/example2.com.  using the Wlc gui I can change the values, but the AP will not keep the updated info.  I have rebooted, the AP and tried pushing out the changes 2-3 times.
Are you configuring WebAuth on c9800 controller? If you are, have a look at the following configuration guide and make sure you follow the steps listed.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213923-configure-a-web-authentication-ssid-on-c.html
CJ
No my AP's are already registered to controller, just trying to change the DNS and domain values inside the 2700 AP via the Wlc 9800.
Rich R
Have you checked you're on the latest code which supports the Wave 1 APs?
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html#anc9
I am on 17.3.3. looking to go to 17.3.4c out of 186 Ap's maybe 10 won't take change. All running same code.
