CLI to see RSSI of associated clients on Autonomous AP?
Muhammed Adnan
Level 4
Level 4
Hello Experts,
What is the "show cli" on autonomous AP that could be used to see the RSSI with which a Wireless client/ WGB is associated?
6 Replies 6
Rasika Nayanajith
"show dot11 association <mac_addr> " output should provide that info.
Rasika
*** Pls rate all useful responses ***
Thank you Rasika for your response. It helped.
""show dot11 association <mac_addr> " was not accepted as a valid cli on the IOS I was running on my AP, however "show dot11 associations all" helped obtained the RSSI of the associated clients.
IW3700-1#show dot11 associations all
Address           : 002c.c8b6.1c78     Name             : IW3700-2
IP Address        : 10.0.0.2           IPv6 Address        : ::
Gateway Address   : 0.0.0.0
Netmask Address   : 0.0.0.0            Interface        : Dot11Radio 1
Bridge-group        : 0
reap_flags_1        : 0x0     ip_learn_type       : 0x0       transient_static_ip : 0x0
Device            : WGB                Software Version : 15.3
CCX Version       : 5                  Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : CiscoSurvey
VLAN              : 0
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 1                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : NONE               Encryption       : Off
Current Rate      : a4.1t2               Capability       : WMM ShortHdr 11h
Supported Rates   : 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -70  dBm           Connected for    : 105 seconds
Signal to Noise   : 25  dB            Activity Timeout : 30 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 238                Packets Output   : 212
Bytes Input       : 27617              Bytes Output     : 43429
Duplicates Rcvd   : 6                  Data Retries     : 303
Decrypt Failed    : 0                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
IP source guard failed : 0             PPPoE passthrough failed : 0
DAI failed : IP mismatch  : 0             src MAC mismatch : 0             target MAC mismatch : 0
Existing IP failed :  0              New IP failed :  0
11w Status       : Off
Address           : e86a.6479.628c     Name             : NONE
IP Address        : 10.0.0.3           IPv6 Address        : ::
Bridge-group        : 0
Device            : WGB-client         Software Version : NONE
CCX Version       : NONE               Client MFP       : Off
State             : Assoc              Parent           : 002c.c8b6.1c78
SSID              : CiscoSurvey
VLAN              : 0
Hops to Infra     : 0
Clients Associated: 0                  Repeaters associated: 0
11w Status       : Off
IW3700-1#
"show dot11 association <mac_addr> " was not accepted as a valid cli on the IOS I was running on my AP.
I expected you to replace <mac_addr> section of that command with your client MAC address :)
So command to be issued like "show dot11 association 002c.c8b6.1c78"
Rasika
//I expected you to replace <mac_addr> section of that command with your client MAC address :)//
That's fairly understood Rasika :). I meant the actual client mac address only :)
Is the RSSI visible with that command output measured on the AP or measured on the client?
I expect it to be measured on the AP and I wonder whether there is a way to check the client measured RSSI from the AP.
That you need to look at the client. I don't think it is reported back to the AP. Typically though (with end user clients) the AP hears the client better than the client hears the AP.
Also bear in mind, the real value (signal strength) is permanently adjusted by both sides depending on the quality in the newer standards. What you see measured are typically the beacons.
