Client Roaming problems with 5508 controller
don
Community Member
Hi guys,
I am having some troubles with client roaming on a 5508 controller running firmware 7.3.101.0. As soon as a client roams outside the range of an AP they lose data flow and do not seem to transition to another AP for about 1 minute.
This is a small network with 6 x AIRCAP3502E-N-K9 AP's (running in H-REAP mode) on the same floor and clients are a mix of HP notebooks, Mac Books, iMacs, iPads and iPhones. There are several seperate SSID's setup and the problem occurs on all. All are WPA2/AES with either a PSK or 802.1X. Both 2.4GHz and 5GHz radios are enabled with auto power and channel selection.
I have tried changing the roaming settings from default and also playing with the AP power settings to no avail.
Is this normal behaviour or is there something I can do to improve the reconnection speed?
11 Replies 11
Leo Laohoo
The decision to roam to which AP is solely at the discretion of the wireless clients.  Please ensure the wireless NIC drivers are up to date.
You can "assist" in the the wireless NIC by ensuring the following:
1.  Disable Client Load Balancing;
2.  Disable 802.11b/g data rates from 1 Mbps up to 12 Mbps.  Make 18 Mbps as "Mandatory" and the rest are "Supported".
Scott Fella
Just to add to Leo's post.... It seems like there might be a configuration issue.  I would change the roaming setting, etc back to default.  I'm also going to assume that you have 100% coverage and that the client device is roaming using the same ssid?  You don't have multiple ssid profiles configured on the client.  If you can post the show run config, that would help us review how your wlc is setup.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
don
Community Member
There is definately 100% coverage infact the AP's do overlap quite a bit in some areas (closest AP's are around 20-25 meters apart).
They are roaming using the same SSID but some clients do have multiple SSID profiles setup. Basically there are 3 SSID/networks, each runs on a different VLAN and used for different purposes (e.g. guest access, local network access etc). Some devices e.g the iPads/iPhones will have all 3 SSID profiles setup but most of the other devices do not. On my test laptop I only have one SSID profile setup and this issue still occurs.
I am not back at this location for a few days but I will post the config once I am able to retreive it. I will also try your suggestions to see if there are any improvements.
don
Community Member
Here is the config (with sensitive information removed);
config sysname REMOVED
config time ntp server 1 REMOVED
config time ntp server 2 REMOVED
config advanced probe limit 2 500
config advanced probe-limit 2 500
config advanced 802.11a channel add 36
config advanced 802.11a channel add 40
config advanced 802.11a channel add 44
config advanced 802.11a channel add 48
config advanced 802.11a channel add 52
config advanced 802.11a channel add 56
config advanced 802.11a channel add 60
config advanced 802.11a channel add 64
config advanced 802.11a channel add 149
config advanced 802.11a channel add 153
config advanced 802.11a channel add 157
config advanced 802.11a channel add 161
config advanced 802.11a tpc-version 2
config advanced 802.11b channel add 1
config advanced 802.11b channel add 6
config advanced 802.11b channel add 11
config advanced 802.11b tpc-version 2
config local-auth method fast server-key encrypt 1 REMOVED
config local-auth eap-profile add REMOVED
config local-auth eap-profile method add leap REMOVED
config local-auth eap-profile method add fast REMOVED
config local-auth eap-profile method add tls REMOVED
config local-auth eap-profile method add peap REMOVED
config local-auth eap-profile cert-issuer cisco REMOVED
config local-auth eap-profile cert-verify cn-verify disable REMOVED
config local-auth eap-profile cert-verify date-valid enable REMOVED
config local-auth eap-profile cert-verify ca-issuer enable REMOVED
config interface address management REMOVED
config interface address service-port 10.1.1.1 255.255.255.0
config interface address virtual 1.1.1.1
config interface address dynamic-interface guest REMOVED
config interface address dynamic-interface internal REMOVED
config interface address dynamic-interface unsecure REMOVED
config interface dhcp management primary REMOVED
config interface vlan management XXX
config interface dhcp service-port disable
config interface hostname REMOVED
config interface create guest XXX
config interface dhcp dynamic-interface guest primary REMOVED
config interface vlan guest XXX
config interface create internal XXX
config interface dhcp dynamic-interface internal primary REMOVED
config interface vlan internal REMOVED
config interface create unsecure REMOVED
config interface dhcp dynamic-interface unsecure primary REMOVED
config interface vlan unsecure XXX
config 802.11b cac voice sip bandwidth 64 sample-interval 20
config 802.11b cac voice sip codec g711 sample-interval 20
config 802.11b 11gsupport enable
config custom-web webtitle "REMOVED"
config custom-web webmessage "Welcome to REMOVED
config custom-web weblogo disable
config license agent max-sessions 9
config license boot base
config database size 2048
config country AU
config mobility group domain REMOVED
config network web-auth port 443
config network rf-network-name default
config network web-auth-port 443
config network multicast l2mcast disable service-port
config network multicast l2mcast disable virtual
config network master-base enable
config 802.11a cac voice sip bandwidth 64 sample-interval 20
config 802.11a cac voice sip codec g711 sample-interval 20
config radius auth add encrypt 1 REMOVED 1812 password 1 REMOVED
config radius auth rfc3576 enable 1
config radius auth retransmit-timeout 1 2
config radius auth network 1 enable
config radius auth management 1 enable
config radius auth enable 1
config rogue rule add ap priority 1 classify malicious SignalStregnth
config rogue rule match all SignalStregnth
config wlan session-timeout 1 1800
config wlan security wpa akm psk set-key hex encrypt 1 REMOVED
config wlan security wpa akm psk enable 1
config wlan security wpa akm 802.1x disable 1
config wlan security wpa enable 1
config wlan security web-auth server-precedence 1 local radius ldap
config wlan session-timeout 2 1800
config wlan security wpa akm psk enable 2
config wlan security wpa akm 802.1x disable 2
config wlan security wpa enable 2
config wlan security web-auth server-precedence 2 local radius ldap
config wlan session-timeout 3 28800
config wlan security wpa wpa2 ciphers aes disable 3
config wlan security wpa wpa2 disable 3
config wlan security wpa akm 802.1x disable 3
config wlan security wpa disable 3
config wlan security web-auth server-precedence 3 local radius ldap
config wlan security web-auth enable 3
config wlan session-timeout 4 43200
config wlan security wpa enable 4
config wlan security web-auth server-precedence 4 radius
config wlan flexconnect local-switching 1 central-dhcp nat-pat disable
config wlan flexconnect local-switching 1 enable
config wlan flexconnect local-switching 2 central-dhcp nat-pat disable
config wlan flexconnect local-switching 2 enable
config wlan flexconnect local-switching 3 central-dhcp nat-pat disable
config wlan flexconnect local-switching 3 enable
config wlan flexconnect local-switching 4 central-dhcp nat-pat disable
config wlan flexconnect local-switching 4 enable
config wlan interface 1 guest
config wlan interface 2 guest
config wlan interface 3 unsecure
config wlan interface 4 internal
config wlan create 1 Guest REMOVED
config wlan wmm allow 1
config wlan create 2 Internal REMOVED
config wlan wmm allow 2
config wlan create 3 "Visitor (Web Auth)" REMOVED
config wlan wmm allow 3
config wlan create 4 Corporate REMOVED
config wlan wmm allow 4
config wlan mfp client enable 1
config wlan exclusionlist 1 disabled
config wlan exclusionlist 1 0
config wlan broadcast-ssid enable 1
config wlan mfp client enable 2
config wlan exclusionlist 2 disabled
config wlan exclusionlist 2 0
config wlan broadcast-ssid disable 2
config wlan mfp client enable 3
config wlan exclusionlist 3 disabled
config wlan exclusionlist 3 0
config wlan broadcast-ssid enable 3
config wlan mfp client enable 4
config wlan exclusionlist 4 disabled
config wlan exclusionlist 4 0
config wlan broadcast-ssid enable 4
config wlan ldap add 4 1
config wlan ldap add 4 2
config wlan radius_server acct disable 3
config wlan radius_server auth disable 3
config wlan radius_server auth add 4 1
config wlan dhcp_server 1 0.0.0.0 required
config wlan enable 1
config wlan enable 2
config wlan dhcp_server 3 0.0.0.0 required
config wlan enable 4
config lag enable
config certificate generate webauth
config ap packet-dump truncate 0
config ap packet-dump buffer-size 2048
config ap packet-dump capture-time 10
config mgmtuser add encrypt admin 1 REMOVED read-write
config ldap simple-bind authenticated encrypt 1 svc_wacldap 1 REMOVED
config ldap add REMOVED 389 CN=Person,CN=Schema,CN=Configuration,DC=XXX,DC=local uid person
config ldap simple-bind authenticated encrypt 2 svc_wacldap 1 REMOVED
config ldap add 2 REMOVED 389 CN=Person,CN=Schema,CN=Configuration,DC=XXX,DC=local uid person
config ldap retransmit-timeout 1 2
config ldap enable 1
config ldap retransmit-timeout 2 2
config ldap enable 2
config spanningtree port mode off 1
config spanningtree port mode off 2
config spanningtree port mode off 3
config spanningtree port mode off 4
config spanningtree port mode off 5
config spanningtree port mode off 6
config spanningtree port mode off 7
config spanningtree port mode off 8
transfer download serverip REMOVED
transfer download path /
transfer download filename NEW_CONFIG.txt
transfer upload datatype config
transfer upload serverip REMOVED
transfer upload path /
transfer upload filename NEW_CONFIG.txt
Use TPC version 1.
Can you post the output to the command "sh run-config no-ap"?
don
Community Member
System Inventory
NAME: "Chassis"    , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9,  VID: V01,  SN: FCW1453L095
Burned-in MAC Address............................ C4:71:FE:97:C3:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 12
Press Enter to continue or to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.101.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... XXX
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... XXX
Last Reset....................................... Software reset
System Up Time................................... 90 days 16 hrs 58 mins 58 secs
System Timezone Location......................... (GMT +9:30) Darwin
Configured Country............................... AU  - Australia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
--More or (q)uit current module or to abort
External Temperature............................. +24 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 38
AP Bundle Information
Error in opening AP images present in flash.
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
                                                         Strong Password Check Features:
         case-check ...........Enabled
         consecutive-check ....Enabled
         default-check .......Enabled
         username-check ......Enabled
Network Information
RF-Network Name............................. default
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Enable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80,443
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
                                                    CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
2  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
7  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
8  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
AP Summary
Number of APs.................................... 8
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
AP06         2     AIR-CAP3502E-N-K9     e0:5f:b9:1c:88:7c           Level 1  LAG      AU       1
AP02         2     AIR-CAP3502E-N-K9     e0:5f:b9:15:f5:4e  default location  LAG      AU       1
AP04         2     AIR-CAP3502E-N-K9     e0:5f:b9:1c:8b:bb  default location  LAG      AU       1
AP03         2     AIR-CAP3502E-N-K9     1c:df:0f:95:2a:4c  default location  LAG      AU       1
AP01         2     AIR-CAP3502E-N-K9     e0:5f:b9:1c:8b:f7  default location  LAG      AU       1
AP05         2     AIR-CAP3502E-N-K9     e0:5f:b9:15:f5:47         Boardroom  LAG      AU       1
AP01         2     AIR-CAP3502E-N-K9     e0:5f:b9:1c:88:85         Melbourne  LAG      AU       1
AP02         2     AIR-CAP3502E-N-K9     e0:5f:b9:1c:88:29  default location  LAG      AU       1
AP Tcp-Mss-Adjust Info
AP Name              TCP State  MSS Size
AP06         disabled   -
AP02         disabled   -
AP04         disabled   -
AP03         disabled   -
AP01         disabled   -
AP05         disabled   -
M-AP01         disabled   -
M-AP02         disabled   -
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Disabled
    802.11a 9M Rate.............................. Disabled
    802.11a 12M Rate............................. Disabled
    802.11a 18M Rate............................. Mandatory
    802.11a 24M Rate............................. Supported
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
    MCS 16....................................... Supported
    MCS 17....................................... Supported
    MCS 18....................................... Supported
    MCS 19....................................... Supported
    MCS 20....................................... Supported
    MCS 21....................................... Supported
    MCS 22....................................... Supported
    MCS 23....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Enabled
        Priority 5............................... Enabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
        Aggregation scheduler.................... Enabled
            Realtime Timeout..................... 10
    A-MSDU Tx:
        Priority 1............................... Enabled
        Priority 2............................... Enabled
        Priority 3............................... Enabled
    Rifs Rx ..................................... Enabled
    Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice CAC Method ............................. Load-Based
   Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
   SIP based CAC ................................ Disabled
   SIP Codec Type ............................... CODEC_TYPE_G711
   SIP call bandwidth ........................... 64
   SIP call bandwith sample-size ................ 20
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
   Video load-based CAC mode..................... Disabled
   Video CAC Method ............................. Static
CAC SIP-Video Configuration
   Best-effort AC - Admission control (ACM)...... Disabled
   Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP Radio........... 200
802.11a Advanced Configuration
Member RRM Information
AP Name                          MAC Address       Admin    Oper        Channel    TxPower
AP06                     10:8c:cf:10:91:80 ENABLED  UP          44*        *1/7 (17 dBm)
AP02                     10:8c:cf:10:92:60 ENABLED  UP          149*       *1/7 (17 dBm)
AP04                     10:8c:cf:11:07:b0 ENABLED  UP          157*       *1/7 (17 dBm)
AP03                     10:8c:cf:11:09:f0 ENABLED  UP          149*       *1/7 (17 dBm)
AP01                     10:8c:cf:11:0c:c0 ENABLED  UP          157*       *1/7 (17 dBm)
AP05                     10:8c:cf:10:90:70 ENABLED  UP          36*        *1/7 (17 dBm)
M-AP01                     10:8c:cf:10:91:e0 ENABLED  UP          48*        *1/7 (17 dBm)
M-AP02                     10:8c:cf:10:79:c0 ENABLED  UP          48*        *1/7 (17 dBm)
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a RRM Neighbor Discover Type............. Transparent
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
  802.11a AP Neighbor Report Interval............ 180 seconds
  802.11a AP Interference Report Interval........ 120 seconds
Leader Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... XXX (XXX)
  Last Run....................................... 377 seconds ago
  TPC Mode....................................... Version 1
  TPCv2 Target RSSI.............................. -60 dBm
  TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
  TPCv2 SOP...................................... -85.0 dBm
  TPCv2 Default Client Ant Gain..................   0.0 dBi
  TPCv2 Path Loss Decay Factor...................   3.6
  TPCv2 Search Intensity......................... 10 Iterations
AP Name                          Channel    TxPower       Allowed Power Levels
AP06                     *44        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP02                     *149       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP04                     *157       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP03                     *149       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP01                     *157       *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP05                     *36        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
M-AP01                     *48        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
M-AP02                     *48        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Leader Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI..
  CleanAir Event-driven RRM option............... Disabled
  CleanAir Event-driven RRM sensitivity.......... Medium
  Channel Assignment Leader...................... XXX (XXX)
  DCA Sensitivity Level.......................... MEDIUM (15 dB)
  DCA 802.11n Channel Width...................... 20 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
    Minimum...................................... 29 days, 18 h 00 m 21 s
    Average...................................... 69 days, 05 h 36 m 17 s
    Maximum...................................... 90 days, 16 h 49 m 40 s
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64,149,
                                                  153,157,161
    Unused Channel List.......................... 100,104,108,112,116,120,124,
                                                  128,132,136,140,165
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... XXX (XXX)
    802.11a Group Member......................... XXX (XXX)
  802.11a Last Run............................... 365 seconds ago
802.11a CleanAir Configuration
Clean Air Solution............................... Enabled
Air Quality Settings:
    Air Quality Reporting........................ Enabled
    Air Quality Reporting Period (min)........... 15
    Air Quality Alarms........................... Enabled
      Air Quality Alarm Threshold................ 35
      Unclassified Interference.................. Disabled
      Unclassified Severity Threshold............ 20
Interference Device Settings:
    Interference Device Reporting................ Enabled
    Interference Device Types:
        TDD Transmitter.......................... Enabled
        Jammer................................... Enabled
        Continuous Transmitter................... Enabled
        DECT-like Phone.......................... Enabled
        Video Camera............................. Enabled
        WiFi Inverted............................ Enabled
        WiFi Invalid Channel..................... Enabled
        SuperAG.................................. Enabled
        Canopy................................... Enabled
        WiMax Mobile............................. Enabled
        WiMax Fixed.............................. Enabled
    Interference Device Alarms................... Enabled
    Interference Device Types Triggering Alarms:
        TDD Transmitter.......................... Disabled
        Continuous Transmitter................... Disabled
        DECT-like Phone.......................... Disabled
        Video Camera............................. Disabled
        SuperAG.................................. Disabled
        Canopy................................... Disabled
        WiMax Mobile............................. Disabled
        WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
    CleanAir ED-RRM State........................ Disabled
    CleanAir ED-RRM Sensitivity.................. Medium
    CleanAir ED-RRM Custom Threshold............. 50
    CleanAir Persistent Devices state............ Disabled
    CleanAir Persistent Device Propagation....... Disabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name            Channel Avg AQ Min AQ Interferers DFS
M-AP02       48      100    100    0
AP05       36      99     99     0
AP06       44      100    100    0
M-AP01       48      100    100    0
AP02       149     100    100    0
AP04       157     100    100    0
AP03       149     100    100    0
AP01       157     99     99     0
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Disabled
    802.11b/g 2M Rate............................ Disabled
    802.11b/g 5.5M Rate.......................... Disabled
    802.11b/g 11M Rate........................... Disabled
    802.11g 6M Rate.............................. Disabled
    802.11g 9M Rate.............................. Disabled
    802.11g 12M Rate............................. Disabled
    802.11g 18M Rate............................. Mandatory
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
802.11n Status:
    A-MPDU Tx:
    A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Voice CAC Method.............................. Load-Based
   SIP call bandwidth: .......................... 64
   SIP call bandwidth sample-size ............... 20
CAC SIP-Video configuration
Maximum Number of Clients per AP................. 200
802.11b Advanced Configuration
AP06                     10:8c:cf:10:91:80 ENABLED  UP          1*         *1/8 (20 dBm)
AP02                     10:8c:cf:10:92:60 ENABLED  UP          1*         *1/8 (20 dBm)
AP04                     10:8c:cf:11:07:b0 ENABLED  UP          6*         *1/8 (20 dBm)
AP03                     10:8c:cf:11:09:f0 ENABLED  UP          11*        *2/8 (17 dBm)
AP01                     10:8c:cf:11:0c:c0 ENABLED  UP          6*         *2/8 (17 dBm)
AP05                     10:8c:cf:10:90:70 ENABLED  UP          1*         *2/8 (17 dBm)
M-AP01                     10:8c:cf:10:91:e0 ENABLED  UP          6*         *1/8 (20 dBm)
M-AP02                     10:8c:cf:10:79:c0 ENABLED  UP          11*        *1/8 (20 dBm)
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b RRM Neighbor Discovery Type............ Transparent
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  802.11b AP Neighbor Report Interval............ 180 seconds
  802.11b AP Interference Report Interval........ 120 seconds
  Last Run....................................... 176 seconds ago
AP06                     *1         *1/8 (20 dBm) [20/17/14/11/8/5/2/-1]
AP02                     *1         *1/8 (20 dBm) [20/17/14/11/8/5/2/-1]
AP04                     *6         *1/8 (20 dBm) [20/17/14/11/8/5/2/-1]
AP03                     *11        *2/8 (17 dBm) [20/17/14/11/8/5/2/-1]
AP01                     *6         *2/8 (17 dBm) [20/17/14/11/8/5/2/-1]
AP05                     *1         *2/8 (17 dBm) [20/17/14/11/8/5/2/-1]
M-AP01                     *6         *1/8 (20 dBm) [20/17/14/11/8/5/2/-1]
M-AP02                     *11        *1/8 (20 dBm) [20/17/14/11/8/5/2/-1]
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... MEDIUM (10 dB)
    Minimum...................................... -82 dBm
    Average...................................... -78 dBm
    Maximum...................................... -70 dBm
  Channel Dwell Times
    Minimum...................................... 0 days, 19 h 10 m 10 s
    Average...................................... 55 days, 08 h 51 m 13 s
    Maximum...................................... 90 days, 16 h 49 m 28 s
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... XXX (XXX)
    802.11b Group Member......................... XXX (XXX)
  802.11b Last Run............................... 164 seconds ago
        Bluetooth Link........................... Enabled
        Microwave Oven........................... Enabled
        802.11 FH................................ Enabled
        Bluetooth Discovery...................... Enabled
        802.15.4................................. Enabled
        Microsoft Device......................... Enabled
        Bluetooth Link........................... Disabled
        Microwave Oven........................... Disabled
        802.11 FH................................ Disabled
        Bluetooth Discovery...................... Disabled
        802.15.4................................. Disabled
        Microsoft Device......................... Disabled
AQ = Air Quality
M-AP02       11      97     97     2
AP05       1       95     94     12
AP06       1       99     99     2
M-AP01       6       98     98     2
AP02       1       96     95     10
AP04       6       93     92     8
AP03       11      91     90     8
AP01       6       96     95     9
Mobility Configuration
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... XXX
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xc3f4
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
c4:71:fe:97:c3:a0  XXX     XXX                               0.0.0.0          Up
Mobility Hash Configuration
IP Address      Hash Key
Self Signed Certificate details
SSC Hash validation.............................. Enabled.
SSC device certificate not present.
Mobility Foreign Map Configuration
WLAN ID     Foreign Mac Address     Interface
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  2
Probe request rate-limiting interval.............  500 msec
Aggregate Probe request interval.................  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
Fastpath Packet Capture.......................... disable
Fastpath Fast Cache Control...................... enable
Fastpath Fast Testmode........................... 0x0
dot11-padding.................................... Disabled
Advanced Hotspot Commands
ANQP 4-way state................................. Disabled
GARP Broadcast state: ........................... Enabled
GAS request rate limit .......................... Disabled
ANQP comeback delay in TUs(TU=1024usec).......... 50
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility....................................
Interface Configuration
Interface Name................................... guest
MAC Address...................................... c4:71:fe:97:c3:af
IP Address....................................... XXX.158.66
IP Netmask....................................... 255.255.255.192
IP Gateway....................................... XXX.158.126
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 358
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (13)
Primary Physical Port............................ LAG (13)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. XXX.158.65
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... internal
IP Address....................................... XXX.158.130
IP Netmask....................................... 255.255.255.128
IP Gateway....................................... XXX.158.129
VLAN............................................. 258
Primary DHCP Server.............................. XXX.156.12
Interface Name................................... management
IP Netmask....................................... 255.255.255.240
VLAN............................................. 158
AP Manager....................................... Yes
Interface Name................................... redundancy-management
IP Address....................................... 0.0.0.0
Interface Name................................... redundancy-port
MAC Address...................................... c4:71:fe:97:c3:a2
Interface Name................................... service-port
MAC Address...................................... c4:71:fe:97:c3:a1
IP Address....................................... 10.1.1.1
IP Netmask....................................... 255.255.255.0
DHCP Protocol.................................... Disabled
Interface Name................................... unsecure
IP Address....................................... XXX.148.2
IP Gateway....................................... XXX.148.254
VLAN............................................. 348
Primary DHCP Server.............................. XXX.148.1
Interface Name................................... virtual
MAC Address...................................... c4:71:fe:97:c3:a0
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ lobby.XXX.gov.au
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... Guest
Network Name (SSID).............................. XXX Guest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 17
Exclusionlist.................................... Disabled
Session Timeout.................................. 36000 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Enabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Disabled
        Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
WLAN Configuration
WLAN Identifier.................................. 2
Profile Name..................................... Internal
Network Name (SSID).............................. XXX-internal
Number of Active Clients......................... 16
Session Timeout.................................. 1800 seconds
CCX - AironetIe Support.......................... Disabled
Radius Servers
Security
        Auth Key Management
WLAN Configuration
WLAN Identifier.................................. 3
Profile Name..................................... Visitor (Web Auth)
Network Name (SSID).............................. XXX-visitor
Interface........................................ unsecure
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
Security
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Web Based Authentication...................... Enabled
        IPv4 ACL........................................ Unconfigured
        IPv6 ACL........................................ Unconfigured
        Web-Auth Flex ACL............................... Unconfigured
        Web Authentication server precedence:
        1............................................... local
        2............................................... radius
        3............................................... ldap
   Client MFP.................................... Optional but inactive (WPA2 not configured)
WLAN Configuration
WLAN Identifier.................................. 4
Profile Name..................................... Corporate
Network Name (SSID).............................. XXX-SECURE
Broadcast SSID................................... Disabled
Number of Active Clients......................... 2
Session Timeout.................................. 43200 seconds
Interface........................................ internal
DHCP Address Assignment Required................. Disabled
Radius Servers
   Authentication................................ XXX.156.37 1812
LDAP Servers
   Server 1...................................... XXX.156.11 389
   Server 2...................................... XXX.156.12 389
Security
   FT Support.................................... Disabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. Mac Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  MgmtTout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
1    NM    XXX.156.37     1812    Enabled   2     2         Enabled   Disabled - none/unknown/group-0/0 none/none
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout  MgmtTout
Authorization Servers
Accounting Servers
LDAP Configuration
Idx  Server Address   Port  Enabled
1    XXX.156.11    389   Yes
2    XXX.156.12    389   Yes
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
    Name ........................................ XXX-SECURE-G
      Certificate issuer ........................ cisco
      Peer verification options:
        Check against CA certificates ........... Enabled
        Verify certificate CN identity .......... Disabled
        Check certificate date validity ......... Enabled
      EAP-FAST configuration:
        Local certificate required .............. No
        Client certificate required ............. No
      Enabled methods ........................... leap fast tls peap
      Configured on WLANs ....................... none
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
FlexConnect Group Summary
FlexConnect Group Summary: Count: 0
Group Name                # Aps
FlexConnect Group Detail
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Peer Route  Info
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
  AP with Manufacturing Installed Certificate.... yes
  AP with Self-Signed Certificate................ no
  AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
                                                    Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
DHCP Info
No leases allocated.
DHCP Opt-82 RID Format:
DHCP Opt-82 Format: binary
DHCP Proxy Behaviour:   enabled
DHCP Server IP Address:.......................... XXX.148.1
  DHCP DISCOVER Count:........................... 311
  DHCP REQUEST Count:............................ 3185
  DHCP INFORM Count:............................. 1
  DHCP DECLINE Count:............................ 0
  DHCP RELEASE Count:............................ 0
  DHCP REPLY Count:.............................. 0
  DHCP OFFER Count:.............................. 194
  DHCP ACK Count:................................ 3038
  DHCP NAK Count:................................ 0
  Tx Fails:...................................... 0
  Last Rx Time:.................................. 28135 seconds ago
  Last Tx Time:.................................. 28135 seconds ago
DHCP Server IP Address:.......................... XXX.156.12
  DHCP DISCOVER Count:........................... 120
  DHCP REQUEST Count:............................ 224
  DHCP INFORM Count:............................. 0
  DHCP OFFER Count:.............................. 64
  DHCP ACK Count:................................ 114
  Last Rx Time:.................................. 417133 seconds ago
  Last Tx Time:.................................. 417133 seconds ago
  DHCP DISCOVER Count:........................... 0
  DHCP REQUEST Count:............................ 0
  DHCP OFFER Count:.............................. 0
  DHCP ACK Count:................................ 0
  Last Rx Time:.................................. 0
  Last Tx Time:.................................. 0
DHCP Server IP Address:.......................... XXX.158.65
  DHCP DISCOVER Count:........................... 5814
  DHCP REQUEST Count:............................ 45839
  DHCP INFORM Count:............................. 44
  DHCP RELEASE Count:............................ 5
  DHCP OFFER Count:.............................. 5235
  DHCP ACK Count:................................ 44872
  Last Rx Time:.................................. 128 seconds ago
  Last Tx Time:.................................. 128 seconds ago
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. AU  - Australia
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory domain allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
AU (-A   ,-NA  😞 A * * * * A * * * * A . . .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6 6 7
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5 9 3
AU (-NZ  ,-NZ  😞 . A . A . A . A A A A A * * * * * * * * * * * A A A A * . .
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Management Frame Protection
  Global Infrastructure MFP state................ DISABLED (*all infrastructure settings are overridden)
  Controller Time Source Valid................... True
                                    WLAN       Client
WLAN ID  WLAN Name                  Status     Protection
1        Guest                      Enabled    Optional
2        Internal                   Enabled    Optional
3        Visitor (Web Auth)         Enabled    Optional but inactive (WPA2 not configured)
4        Corporate                  Enabled    Optional
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Disabled
CustomLogo....................................... None
Custom Title..................................... XXX Guest Network
Custom Message................................... Welcome to Health Workforce Australia
Custom Redirect URL.............................. None
Web Authentication Type.......................... Customized
Logout-popup..................................... Enabled
External Web Authentication URL.................. None
Configuration Per Profile:
WLAN ID: 3
   WLAN Status................................... Enabled
   Web Security Policy........................... Web Based Authentication
   Global Status................................. Enabled
   WebAuth Type.................................. Internal
Core dump Configuration
Core Dump is disabled
Rogue AP Configuration
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Rogue Detection Report Interval.................. 10
Rogue Detection Min Rssi......................... -128
Rogue Detection Transient Interval............... 0
Total Rogues(AP+Ad-hoc) supported................ 2000
Total Rogues classified.......................... 126
MAC Address        Classification     # APs # Clients Last Heard
00:02:6f:52:c6:1c  Unclassified       5     0         Tue Jun  4 09:50:18 2013
00:04:ed:55:6b:9a  Pending            1     0         Tue Jun  4 09:50:18 2013
00:04:ed:8b:e5:47  Pending            1     0         Tue Jun  4 09:50:18 2013
00:04:ed:ba:f3:da  Unclassified       3     0         Tue Jun  4 09:50:18 2013
00:04:ed:ba:fa:26  Unclassified       1     0         Tue Jun  4 09:50:18 2013
00:04:ed:d1:b5:a1  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:04:ed:d5:d0:34  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:04:ed:d7:48:2c  Unclassified       2     0         Tue Jun  4 09:47:19 2013
00:04:ed:da:9b:46  Unclassified       1     0         Tue Jun  4 09:40:47 2013
00:04:ed:de:3a:4b  Unclassified       1     0         Tue Jun  4 09:50:18 2013
00:0c:42:fc:91:11  Pending            1     0         Tue Jun  4 09:50:18 2013
00:12:5f:08:4c:e4  Unclassified       1     0         Tue Jun  4 09:50:18 2013
00:13:80:24:ee:30  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:13:d3:7b:12:26  Unclassified       5     1         Tue Jun  4 09:50:18 2013
00:15:6d:82:b9:9f  Unclassified       1     0         Tue Jun  4 09:34:38 2013
00:15:6d:8e:12:c9  Unclassified       2     0         Tue Jun  4 09:47:19 2013
00:15:70:42:a7:70  Unclassified       4     0         Tue Jun  4 09:50:18 2013
00:15:70:42:a7:71  Unclassified       3     0         Tue Jun  4 09:50:18 2013
00:15:70:42:a7:72  Unclassified       2     0         Tue Jun  4 09:47:19 2013
00:18:f8:28:49:66  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:19:a9:a5:d5:f1  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:1a:1e:60:7e:80  Unclassified       1     0         Tue Jun  4 09:30:40 2013
00:1a:1e:60:7e:81  Unclassified       1     0         Tue Jun  4 09:33:39 2013
00:1b:2f:97:fe:3c  Unclassified       1     0         Tue Jun  4 09:50:18 2013
00:1c:df:b1:3b:95  Unclassified       1     0         Tue Jun  4 09:34:00 2013
00:1d:46:fe:59:90  Pending            1     0         Tue Jun  4 09:50:18 2013
00:1d:46:fe:7a:c0  Unclassified       6     0         Tue Jun  4 09:50:18 2013
00:1d:46:fe:7a:c1  Unclassified       6     0         Tue Jun  4 09:50:18 2013
00:1d:7e:c3:64:38  Unclassified       2     0         Tue Jun  4 09:50:18 2013
00:1e:2a:ca:6f:83  Unclassified       3     0         Tue Jun  4 09:50:18 2013
00:22:0c:94:a3:e0  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:22:3f:e5:74:f0  Unclassified       2     0         Tue Jun  4 09:50:18 2013
00:22:3f:e5:86:30  Unclassified       1     0         Tue Jun  4 09:40:38 2013
00:22:3f:e5:86:b0  Unclassified       2     0         Tue Jun  4 09:50:18 2013
00:24:14:a9:97:20  Unclassified       1     0         Tue Jun  4 09:40:53 2013
00:24:b2:51:43:ae  Unclassified       1     0         Tue Jun  4 09:50:18 2013
00:24:b2:6e:f3:f4  Unclassified       1     0         Tue Jun  4 09:34:03 2013
00:25:9c:7e:c9:5c  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:25:9c:bf:22:16  Unclassified       1     0         Tue Jun  4 09:37:02 2013
00:26:0b:4c:19:60  Unclassified       3     0         Tue Jun  4 09:50:18 2013
00:26:18:ec:bb:c4  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:26:99:f0:4f:b0  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:60:64:33:94:52  Unclassified       1     0         Tue Jun  4 09:33:34 2013
00:60:64:34:60:70  Unclassified       1     0         Tue Jun  4 09:47:19 2013
00:60:64:3e:ad:68  Unclassified       2     0         Tue Jun  4 09:50:18 2013
00:60:64:56:54:4d  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:60:64:76:f1:16  Unclassified       3     0         Tue Jun  4 09:47:19 2013
00:60:64:86:a4:6a  Unclassified       1     0         Tue Jun  4 09:44:20 2013
00:8e:f2:89:81:1a  Unclassified       3     0         Tue Jun  4 09:50:18 2013
02:1a:11:ff:a8:0a  Unclassified       1     0         Tue Jun  4 09:47:19 2013
08:17:35:82:66:e0  Unclassified       1     0         Tue Jun  4 09:44:20 2013
08:17:35:82:66:e1  Unclassified       1     0         Tue Jun  4 09:50:18 2013
08:17:35:82:66:e2  Pending            1     0         Tue Jun  4 09:50:18 2013
08:76:ff:d8:dc:69  Unclassified       1     0         Tue Jun  4 09:40:53 2013
10:bf:48:d2:f8:88  Unclassified       1     0         Tue Jun  4 09:44:20 2013
1c:1d:67:2d:21:00  Pending            1     0         Tue Jun  4 09:50:18 2013
1c:af:f7:90:24:10  Unclassified       1     0         Tue Jun  4 09:34:00 2013
20:4e:7f:a0:7f:f4  Unclassified       1     0         Tue Jun  4 09:40:47 2013
24:01:c7:ec:f8:d0  Unclassified       1     0         Tue Jun  4 09:47:19 2013
24:65:11:64:cc:f9  Unclassified       1     0         Tue Jun  4 09:47:19 2013
24:65:11:75:2d:e9  Unclassified       1     0         Tue Jun  4 09:40:47 2013
24:b6:57:5a:e2:f0  Unclassified       1     0         Tue Jun  4 09:50:18 2013
24:b6:57:5a:e2:f4  Unclassified       1     0         Tue Jun  4 09:47:19 2013
24:b6:57:5a:e2:f6  Unclassified       1     0         Tue Jun  4 09:47:19 2013
2c:36:f8:0c:23:30  Unclassified       1     0         Tue Jun  4 09:50:18 2013
2c:36:f8:0c:23:32  Unclassified       1     0         Tue Jun  4 09:34:00 2013
2c:36:f8:0c:23:33  Unclassified       1     0         Tue Jun  4 09:44:20 2013
2c:36:f8:0c:23:34  Unclassified       1     0         Tue Jun  4 09:50:18 2013
2c:36:f8:d9:32:a0  Unclassified       1     0         Tue Jun  4 09:44:20 2013
2c:36:f8:d9:32:a1  Pending            1     0         Tue Jun  4 09:50:18 2013
34:e0:cf:ec:4f:e5  Unclassified       3     1         Tue Jun  4 09:50:18 2013
3c:ce:73:39:15:72  Pending            1     0         Tue Jun  4 09:50:18 2013
40:b4:f0:17:57:04  Unclassified       1     0         Tue Jun  4 09:40:38 2013
44:2b:03:7e:f1:bf  Unclassified       1     0         Tue Jun  4 09:38:28 2013
44:e4:d9:84:5c:f0  Unclassified       1     0         Tue Jun  4 09:31:01 2013
44:e4:d9:84:5c:f1  Unclassified       1     0         Tue Jun  4 09:47:19 2013
44:e4:d9:84:5c:f2  Unclassified       1     0         Tue Jun  4 09:50:18 2013
44:e4:d9:84:5c:f3  Unclassified       1     0         Tue Jun  4 09:34:00 2013
4c:60:de:fd:a0:16  Unclassified       1     0         Tue Jun  4 09:50:18 2013
4c:60:de:fd:fb:78  Unclassified       2     0         Tue Jun  4 09:50:18 2013
58:98:35:9a:d7:af  Unclassified       1     0         Tue Jun  4 09:44:20 2013
58:98:35:a5:23:d5  Pending            1     0         Tue Jun  4 09:50:18 2013
5c:50:15:24:52:a0  Pending            1     0         Tue Jun  4 09:50:18 2013
5c:50:15:24:52:a2  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:24:52:a3  Unclassified       2     0         Tue Jun  4 09:44:20 2013
5c:50:15:24:52:a4  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:25:f6:30  Unclassified       1     0         Tue Jun  4 09:47:19 2013
5c:50:15:25:f6:32  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:25:f6:33  Unclassified       1     0         Tue Jun  4 09:47:19 2013
5c:50:15:25:f6:34  Unclassified       2     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:2f:20  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:d9:2f:22  Unclassified       1     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:2f:23  Unclassified       2     0         Tue Jun  4 09:40:19 2013
5c:50:15:d9:2f:24  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:d9:3c:20  Unclassified       1     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:3c:22  Unclassified       2     0         Tue Jun  4 09:44:20 2013
5c:50:15:d9:3c:23  Unclassified       1     0         Tue Jun  4 09:50:18 2013
5c:50:15:d9:3c:24  Unclassified       2     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:d6:d0  Unclassified       2     0         Tue Jun  4 09:50:18 2013
5c:50:15:d9:d6:d2  Unclassified       2     0         Tue Jun  4 09:50:18 2013
5c:50:15:d9:d6:d3  Unclassified       2     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:de:32  Unclassified       1     0         Tue Jun  4 09:44:20 2013
5c:50:15:d9:de:33  Unclassified       1     0         Tue Jun  4 09:47:19 2013
5c:50:15:d9:de:34  Unclassified       1     0         Tue Jun  4 09:30:40 2013
74:44:01:56:30:94  Unclassified       1     0         Tue Jun  4 09:33:38 2013
74:44:01:56:34:21  Unclassified       1     0         Tue Jun  4 09:33:39 2013
74:44:01:9e:66:52  Unclassified       2     0         Tue Jun  4 09:44:20 2013
90:1d:27:0e:66:62  Unclassified       1     0         Tue Jun  4 09:50:18 2013
90:a7:c1:01:37:57  Unclassified       1     0         Tue Jun  4 09:47:19 2013
90:f6:52:52:cd:9f  Unclassified       1     0         Tue Jun  4 09:37:02 2013
9c:c7:a6:25:44:12  Unclassified       3     0         Tue Jun  4 09:50:18 2013
a8:54:b2:92:fe:9f  Unclassified       3     0         Tue Jun  4 09:47:19 2013
a8:54:b2:92:fe:c3  Unclassified       2     0         Tue Jun  4 09:34:00 2013
a8:92:2c:2f:18:6a  Unclassified       1     0         Tue Jun  4 09:44:20 2013
ac:4b:c8:3d:ef:42  Unclassified       1     0         Tue Jun  4 09:44:20 2013
ac:86:74:05:b9:12  Pending            1     0         Tue Jun  4 09:50:18 2013
bc:f6:85:c0:e0:b6  Unclassified       1     0         Tue Jun  4 09:41:02 2013
c0:8a:de:1f:44:c9  Unclassified       1     0         Tue Jun  4 09:35:29 2013
c4:0a:cb:89:ec:c0  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c4:0a:cb:89:ec:c2  Unclassified       1     0         Tue Jun  4 09:44:20 2013
c4:0a:cb:89:ec:c3  Unclassified       1     0         Tue Jun  4 09:47:19 2013
c4:0a:cb:89:ec:c4  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c4:64:13:c5:4c:1b  Unclassified       1     0         Tue Jun  4 09:40:53 2013
c8:d3:a3:5a:c0:2a  Pending            1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:1b:26:20  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:1b:26:22  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:1b:26:23  Unclassified       1     0         Tue Jun  4 09:40:53 2013
c8:f9:f9:1b:26:24  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:1b:26:82  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:1b:26:83  Unclassified       1     0         Tue Jun  4 09:34:00 2013
c8:f9:f9:1b:26:84  Unclassified       1     0         Tue Jun  4 09:47:19 2013
c8:f9:f9:83:08:a0  Pending            1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:83:08:a2  Unclassified       1     0         Tue Jun  4 09:50:18 2013
c8:f9:f9:83:08:a3  Unclassified       1     0         Tue Jun  4 09:44:20 2013
c8:f9:f9:83:08:a4  Pending            1     0         Tue Jun  4 09:50:18 2013
d8:24:bd:d4:6d:50  Unclassified       1     0         Tue Jun  4 09:44:20 2013
d8:24:bd:d4:6d:52  Pending            1     0         Tue Jun  4 09:50:18 2013
e0:05:c5:30:ba:a8  Unclassified       3     0         Tue Jun  4 09:50:18 2013
f0:7d:68:7e:e6:18  Unclassified       1     0         Tue Jun  4 09:50:18 2013
f4:ec:38:b9:96:07  Unclassified       1     0         Tue Jun  4 09:44:20 2013
f8:d1:11:77:87:3d  Unclassified       3     0         Tue Jun  4 09:47:19 2013
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Total Rogues(Ad-Hoc+AP) supported ............... 2000
Total Ad-Hoc entries ............................ 9
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
00:00:48:20:aa:65   02:5f:c9:cc:96:7e   Alert              2        Tue Jun  4 09:50:18 2013
00:0e:10:11:e1:aa   6a:4a:c7:65:7c:60   Alert              4        Tue Jun  4 09:50:18 2013
00:0e:10:12:06:56   0e:c5:18:50:69:29   Alert              3        Tue Jun  4 09:50:18 2013
00:19:88:13:16:78   02:26:d6:14:9b:95   Alert              1        Tue Jun  4 09:44:20 2013
00:25:56:77:a1:f7   da:a6:9e:a8:bf:d7   Alert              1        Tue Jun  4 09:40:47 2013
06:27:22:ff:18:0d   06:27:22:ff:18:0d   Alert              1        Tue Jun  4 09:40:53 2013
0a:27:22:ff:18:0d   0a:27:22:ff:18:0d   Alert              3        Tue Jun  4 09:40:53 2013
c2:9f:db:e9:58:51   c2:9f:db:e9:58:51   Alert              1        Tue Jun  4 09:40:53 2013
c6:9f:db:e9:58:51   c6:9f:db:e9:58:51   Alert              1        Tue Jun  4 09:40:53 2013
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
Total Rogue Clients supported.................... 2500
Total Rogue Clients present...................... 2
MAC Address        State              # APs Last Heard
00:23:6c:7d:8d:4a  Alert              3     Tue Jun  4 09:40:53 2013
18:20:32:c3:de:7a  Alert              1     Tue Jun  4 09:40:53 2013
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State    Type          Match Hit Count
1        SignalStregnth          Disabled Malicious     All   0
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name   Start IP                                End IP                                  Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
Number of Clients................................ 0
Client Mac         Stream Name  Stream Type  Radio WLAN  QoS    Status
WLC Voice Call Statistics
WLC Voice Call Statistics for 802.11b Radio
WMM TSPEC CAC Call Stats
  Total num of Calls in progress................. 0
  Num of Roam Calls in progress.................. 0
  Total Num of Calls Admitted.................... 0
  Total Num of Roam Calls Admitted............... 0
  Total Num of exp bw requests received.......... 0
  Total Num of exp bw requests Admitted.......... 0
  Total Num of Calls Rejected.................... 0
  Total Num of Roam Calls Rejected............... 0
  Num of Calls Rejected due to insufficent bw.... 0
  Num of Calls Rejected due to invalid params.... 0
  Num of Calls Rejected due to PHY rate.......... 0
  Num of Calls Rejected due to QoS policy........ 0
SIP CAC Call Stats
  Total Num of Calls in progress................. 0
  Total Num of Preferred Calls Received.......... 0
  Total Num of Preferred Calls Admitted.......... 0
  Total Num of Ongoing Preferred Calls........... 0
  Total Num of Calls Rejected(Insuff BW)......... 0
  Total Num of Roam Calls Rejected(Insuff BW).... 0
KTS based CAC Call Stats
WLC Voice Call Statistics for 802.11a Radio
SIP CAC Call Stats
WLC IPv6 Summary
Global Config............................... Enabled
Reachable-lifetime value.................... 300
Stale-lifetime value........................ 86400
Down-lifetime value......................... 30
RA Throttling............................... Disabled
RA Throttling allow at-least................ 1
RA Throttling allow at-most................. 1
RA Throttling max-through................... 10
RA Throttling throttle-period............... 600
RA Throttling interval-option............... passthrough
NS Mulitcast CacheMiss Forwarding........... Disabled
don
Community Member
I have tried all suggestions above but there has been no improvement
don
Community Member
Does anyone have any more suggestions?
I have likely the same issue with a customer with Broadcom wireless nics.
Bad drivers or sticky clients is the main issue I think.
http://www.cisco.com/en/US/docs/wireless/technology/vowlan/bestpractices/EntBP-AppMobDevs-on-Wlans.pdf
Erik
I've seen similier issues. Thanks for the excellent link Erik.
How does the channel layout look? If there is quite a bit of overlap, checking the AP channels to make sure they are spaced correctly MIGHT help...
