Clients are dicconected intermittently 10 - 20 minutes
Hello everyone I hope you can help me because I really need it.
I have two WLC 5508 and some AP's 1131 and 3602. I don't know why but my clients are lossing connection to WLAN here some logs from WLC.
[01:51:55 p.m.] Jonatan Sosa Franco: dot1xMsgTask: Aug 15 18:49:29.829: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:49:14.629: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:48:57.629: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:48:07.225: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 68:7f:74:68:2c:91
*dot1xMsgTask: Aug 15 18:46:35.421: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 00:23:14:bc:f4:c4
*spamApTask4: Aug 15 18:46:27.305: %CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:103 The system could not release exclusive access of AP entry for 84:78:ac:c0:87:30 in the database
*spamApTask4: Aug 15 18:46:26.615: %LWAPP-3-RD_ERR6: spam_lrad.c:9849 APs (84:78:ac:c0:87:30) regulatory domain (-N) is not supported in country (US ), slot 80211a (1) supports -A
*apfReceiveTask: Aug 15 18:46:26.370: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:289 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*dot1xMsgTask: Aug 15 18:45:57.421: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 5c:e2:f4:f7:d1:72
*dot1xMsgTask: Aug 15 18:44:16.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client cc:55:ad:6d:8f:47
*apfMsConnTask_3: Aug 15 18:44:13.455: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: cc:55:ad:6d:8f:47.
*dot1xMsgTask: Aug 15 18:43:33.221: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:43:18.222: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:43:15.021: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 00:23:6c:1c:63:36
*dot1xMsgTask: Aug 15 18:43:02.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*Dot1x_NW_MsgTask_6: Aug 15 18:42:35.732: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 00:13:02:3d:e7:f6
*Dot1x_NW_MsgTask_6: Aug 15 18:42:35.732: %DOT1X-3-ABORT_AUTH: 1x_bauth_sm.c:447  Authentication Aboted for client 00:13:02:3d:e7:f6
*dot1xMsgTask: Aug 15 18:42:26.821: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client f4:0b:93:a5:f5:2f
*apfMsConnTask_7: Aug 15 18:42:23.606: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: f4:0b:93:a5:f5:2f.
*Dot1x_NW_MsgTask_6: Aug 15 18:42:05.699: %DOT1X-3-AAA_AUTH_SEND_FAIL: 1x_aaa.c:597 Unable to send AAA message for client 00:13:02:3d:e7:f6
*Dot1x_NW_MsgTask_6: Aug 15 18:42:05.697: %DOT1X-3-ABORT_AUTH: 1x_bauth_sm.c:447  Authentication Aboted for client 00:13:02:3d:e7:f6
*dot1xMsgTask: Aug 15 18:42:05.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M3 retransmissions exceeded for client 00:13:02:3d:e7:f6
*dot1xMsgTask: Aug 15 18:40:25.221: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:475 Max EAP retransmissions exceeded for client 18:e7:f4:7c:3b:88
*webauthRedirect: Aug 15 18:40:06.377: %EMWEB-3-READ_ERROR: webauth_redirect.c:938 read error on server socket
*dot1xMsgTask: Aug 15 18:39:51.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:39:36.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:39:19.821: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 18:20:32:34:1c:42
*dot1xMsgTask: Aug 15 18:39:16.221: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 4c:b1:99:ed:f3:5e
*dot1xMsgTask: Aug 15 18:39:02.021: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 4c:b1:99:ed:f3:5e
*dot1xMsgTask: Aug 15 18:38:47.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client 4c:b1:99:ed:f3:5e
*dot1xMsgTask: Aug 15 18:38:45.821: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:456 Max EAPOL-key M1 retransmissions exceeded for client cc:55:ad:6d:8f:47
*apfMsConnTask_5: Aug 15 18:38:42.748: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: cc:55:ad:6d:8f:47.
*spamApTask3: Aug 15 18:38:34.872: %CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:103 The system could not release exclusive access of AP entry for 84:78:ac:c0:87:30 in the database
*spamApTask3: Aug 15 18:38:34.185: %LWAPP-3-RD_ERR6: spam_lrad.c:9849 APs (84:78:ac:c0:87:30) regulatory domain (-N) is not supported in country (US ), slot 80211a (1) supports -A
*apfReceiveTask: Aug 15 18:38:33.938: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:289 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*apfMsConnTask_6: Aug 15 18:36:23.285: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 80:60:07:fd:d4:f0.
*Dot1x_NW_MsgTask_3: Aug 15 18:36:05.902: %DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client c4:85:08:89:f3:9b - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 00
*dot1xMsgTask: Aug 15 18:35:41.817: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:475 Max EAP retransmissions exceeded for client 74:e1:b6:92:65:09
*apfMsConnTask_6: Aug 15 18:35:18.777: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 80:60:07:fd:d4:f0.
*dot1xMsgTask: Aug 15 18:35:12.817: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 30:17:c8:43:0c:2d
*apfMsConnTask_5: Aug 15 18:34:12.772: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:17:c8:43:0c:2d.
*dot1xMsgTask: Aug 15 18:33:58.217: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 5c:e2:f4:f7:d1:72
*dot1xMsgTask: Aug 15 18:33:49.217: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:475 Max EAP retransmissions exceeded for client c8:6f:1d:04:5d:5a
*apfMsConnTask_5: Aug 15 18:33:17.082: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:203 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:17:c8:43:0c:2d.
*dot1xMsgTask: Aug 15 18:31:53.617: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3136 Max EAP identity request retries (3) exceeded for client 5c:e2:f4:f7:d1:72
*dot1xMsgTask: Aug 15 18:31:06.017: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:475 Max EAP retransmissions exceeded for client 88:53:2e:0f:99:66
*spamApTask4: Aug 15 18:29:18.178: %CAPWAP-3-SEM_RELEASE_ERR: capwap_ac_db.c:103 The system could not release exclusive access of AP entry for 84:78:ac:c0:87:30 in the database
*spamApTask4: Aug 15 18:29:17.491: %LWAPP-3-RD_ERR6: spam_lrad.c:9849 APs (84:78:ac:c0:87:30) regulatory domain (-N) is not supported in country (US ), slot 80211a (1) supports -A
*apfReceiveTask: Aug 15 18:29:17.246: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:289 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
Regards...
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
To make it simple... on a Windows and many other devices, you have some choices:
WPA-Personal <-- Preshared Key
WPA2-Personal <--Preshared Key
WPA-Enterprise <--802.1x
WPA2-Enterprise <--802.1x
When using either of these, your WLC needs to have WPA+WPA2.  When you specify 802.1x, you can setup on the radius server to use PEAP, EAP-TLS or machine authentication.  These are defined on the Radius and has to also match what you have on the client.
See below:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
37 Replies 37
ROBERT T
Level 4
Level 4
This is not the same, but very similar to an issue I had after upgrading to 7.3, see the link below for more details.
http://www.goatnetworking.com/forum/viewtopic.php?f=8&t=1771&p=1844#p1844
I have 7.2.110 version and I have disable that options...
What type of clients?  Can you post your show wlan
Scott
-Scott
Well they're Laptops, tablets, MAC, etc
by the way this happened in every wlan I have 6
Sorry Scott
Here's the information:
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... Ferromex
Network Name (SSID).............................. Ferromex
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 85
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 28800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ usuarios ferromex
--More-- or (q)uit
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... 10.10.40.10
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
   Authentication................................ 10.10.40.15 1812
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Enabled
        Encryption:..................................... 104-bit WEP
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
--More-- or (q)uit
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
--More-- or (q)uit
  WAN Metrics configuration
    Link status.................................. 0
    Link symmetry................................ 0
    Downlink speed............................... 0
    Uplink speed................................. 0
Mobility Services Advertisement Protocol....... Disabled
Scott Fella
You are doing leap? What does the radius server show in the logs?
-Scott
I'm using PEAP
Scott Fella
PEAP is using wpa + wpa2 and then 802.1x
-Scott
Well I just select 802.1x I have this screen.
I forgot to tell you I'm using ISE for Auth
Same here... I don't deploy PEAP the way you have it though.
-Scott
Scott Fella
Here is PEAP
-Scott
Ok so I need to change security configuration as you do?
