Clients are dropping when usage is high
timgrantham
Level 2
Level 2
I've tried everything that I can think of, and this is a strange one to me.
I have a 9130AXI single AP, with EWC 17.7.1, whenever a client is transferring at high speed on the 5GHz radio, all clients drop off, including the one transferring data, move off to the 2.4GHz for a few seconds, and then back to the 5GHz radio for a while, and then after 30 seconds it will go back to 2.4 and so it continues.
It's almost as though if it hits 80% on the radio usage, then it will do something that will say I've had enough go somewhere else.
But if this is the case, I can't find anything that is set that would cause this.
Any help would be really appreciated!
-Tim
6 Replies 6
Haydn Andrews
Couple of things:
First 17.7.1 isn't Cisco's current recommended version it is 17.6.2: https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html
You mention 80% can you confirm that load balancing is not enabled for the SSID?
What happens if you make the SSID 5 GHz only?
Also what channel is the 5GHz operating on, and how wide?
Can you provide the config of the WLC
Suggest conducting a radio trace on a couple of the clients and running the output through the debug analyser for an easier to read version: https://cway.cisco.com/wireless-debug-analyzer/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Haydn,
Thanks for the reply.
If I make the channel 5GHz only then clients will drop, and rejoin that channel a short while after.
Point taken in relation to 17.7.1, and I will downgrade the access point to see if this makes any difference, there are no features that I need in 17.7.1 that isn't there in 17.6.2.
That's a good idea about the radio trace, I had forgotten all about that and will try it now!!
As for the utilisation, there does seem to be this 80% cut off as if I keep it below 79% by throttling what the NAS can send, then it's fine.
It's operating on channels 100 at 80Mhz wide.
Thanks for your help!!
-Tim
jagan.chowdam
Also, what's the AP Channel utilization (on AP 360 page) when client transmitting?
timgrantham
Level 2
Level 2
I tried 17.6.2 and re-did the configuration from scratch (it's only me using it here at home), and it still did it - so went back to 7.17.1 and this evening I have played with every setting I could find.
And boy are there a lot!
But it hasn't done it for the past hour since I disabled "Fastlane + ASR" in the WLAN profile.
I always tell folks to keep the WLAN as simple as possible.  Disable all the features and see how well it works.  The issue with features, is that devices have issues connecting because either the device doesn't understand or support that setting or the ap implements the standard a different way that causes issues to the clients.  When having issues, start with an open SSID and work your way up by adding features.  Then test with PSK and 802.1x with adding one feature at a time.
-Scott
Rich R
Interesting - sounds like a bug ...
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
