Compatibilidad WLC 3504 con AIR-AP2802I-A-K9, AIR-CAP1532E-A-K9
PaulReveco
Hello community,
Due to a failure of a WLC 5508, this device has to be changed for a 3504, it is not observed in the datasheet that it supports the AIR-AP2802I-A-K9, AIR-CAP1532E-A-K9 that the other equipment was lifting.
The IOS would have to be modified to support the new IOS.
3504 controller supports newest OS release 8.10.162.0. and that release supports your mentioned AP models. refer below document to find more details.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr6.html
regards,
KB
mark the answer as solution and up vote if this solved your concern
Good luck
KB
regards,
KB
Good luck
KB
PaulReveco
Could the license be transferred from a 5508 to a 3504?
yes,
if it is classic license, you need to rehost it from license portal.
if it is smart license, you can add new controller to smart license portal to utilize AP licenses.
Good luck
KB
Leo Laohoo
3504 is RTU license.
