Connect WLC 4402 and CATALYST 6500 With LAG.
c-pirault
Hello !
Side Catalyst 6509 :
cata6#sho running-config interface gigabitEthernet 8/15
Building configuration...
Current configuration : 224 bytes
interface GigabitEthernet8/15
switchport
switchport mode trunk
no ip address
channel-protocol lacp
channel-group 4 mode active
end
cata6#sho running-config interface gigabitEthernet 8/45
interface GigabitEthernet8/45
switchport
no ip address
end
et
cata6#sho running-config interface port-channel 4
Current configuration : 149 bytes
interface Port-channel4
description vers wificontrol
switchport
no ip address
end
Side WLC 4402 :
(Cisco Controller) >show port summary
           STP   Admin   Physical   Physical   Link   Link    Mcast
Pr  Type   Stat   Mode     Mode      Status   Status  Trap   Appliance   POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Disable Enable     N/A
2  Normal  Forw Enable  Auto       1000 Full  Up     Disable Enable     N/A
(Cisco Controller) >show lag summary
LAG Enabled
and :
(Cisco Controller) >show mirror ap
AP
(Cisco Controller) >show mirror foreignAp
Foreign AP Port
(Cisco Controller) >show mirror mac
Client MAC        Type
On the web admin interface of the 4402,  the 2 ports GigaEthernet are in mirror mode BUT it is not possible to disable (when i click on "apply" it return to enable). Even if i disable the LAG (and i reboot) I CANNOT disable the mirror mode of the 2 ports.
In the config guide it is noted :
"Port mirroring is not supported when link aggregation (LAG) is enabled on the controller"
Yes i agree BUT i cannot disable !!!
The WLAN work apparently good, BUT the traffic is VERY similar across the 2 interfaces (verify by SNMP/rrdtool side catalyst) AND a ping toward the management-interface of the 4402 show a DUP response :
root@net-adm:~# ping wificontrol
PING wificontrol (10.3.254.159) 56(84) bytes of data.
64 bytes from wificontrol (10.3.254.159): icmp_req=1 ttl=64 time=0.393 ms
64 bytes from wificontrol (10.3.254.159): icmp_req=1 ttl=64 time=0.404 ms (DUP!)
64 bytes from wificontrol (10.3.254.159): icmp_req=2 ttl=64 time=0.316 ms
64 bytes from wificontrol (10.3.254.159): icmp_req=2 ttl=64 time=0.323 ms (DUP!)
64 bytes from wificontrol (10.3.254.159): icmp_req=3 ttl=64 time=0.347 ms
64 bytes from wificontrol (10.3.254.159): icmp_req=3 ttl=64 time=0.355 ms (DUP!)
It seems that the traffic is mirrored on the 2 ports !!!
It's not very useful to have the same traffic, instead a sharing between the 2 ports .
WHERE IS MY MISTAKE ???
Thanks a lot for your help.
     Regards.
2 Accepted Solutions
Michel,
     The WLC does not negotiate a protocol for etherchannel.
So you'll need to issue the follwoing commands under the G8/15 and 8/45
no channel-protocol lacp
channel-group 4 mode on
As for the WLC side, you should be fine if the native is VLAN 1, or if you are tagging the management/ap-manager interface(s)
HTH,
Steve
Please remember to rate helpful posts or to mark the quesiton as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Michel,
     Stephen is correct. +5 Stephen.. and a native vlan statement is not needed as long as your management and ap-manager interfaces have a vlan assigned to them in the controller
6 Replies 6
Chuck Dillon
Hello Mitchel,
I do not see a native vlan defined or any other vlans at all.
switchport trunk native vlan
Michel,
HTH,
Steve
HTH,
Steve
Michel,
Hello !
I modify this and try again and post the result later.
But i don't undertsand why the ports are in mirror mode ?
Thanks.
Hello again !
Good response !
It was the lacp which don't work with the 4402.
I no longer have a duplicate traffic onto the 2 ports and the ping DUP disappear.
But it is always impossible to disable the mirror mode of the 2 ports onto the web user interface of the 4402.
I think for a bug in the GUI.
Thanks a lot and bravo to everybody !
Hello !
In fact i am on the default native VLAN : idem for the Giga 8/45 and Giga 8/15
cata6#show interfaces gigabitEthernet 8/15 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down (suspended member of bundle Po4)
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
