Connection serial to AP 3802
Odbayar
I need some help connecting AP3802.
I am using a serial cable and putty.
Speed:9600
Data bits: 8
Stop bits:1
I have tried every speed. The result is the same. Please help me
Odbayar
USB to serial is not working. Directly serial connection working fine.
Leo Laohoo
If the AP is on 17.15.X, the baud rate needs to be changed to 115200.
I have tried 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 230400, 460800, 921600.
Odbayar
Rich R
Cisco APs are very "fussy" with console cables. Before buying a cable always check the reviews to make sure they work with Cisco APs.  Even if they work with Cisco routers and switches does not mean they will work with APs.  Generally cables based on genuine (not counterfeit) FTDI chipset will work.
