Embedded Wireless Controller on Catalyst 9105AX Access Points
We are going to purchase Access points C9115AXI-I and C9115AXI-EWC-I . Both are same prices
But C9115AXI-EWC-I is announced by Cisco to be end of sale end of this month. So we can purchase only C9115AXI-I with the DNA essential license
I need to confirm that we should be able to buy APs C9115AXI-I and to convert one of them this to EWC to act as master controller using the software available on the software download page shown below
C9100 EWC AP bundle image
C9800-AP-universalk9.17.12.03.zip
Or we would have any issue at this time
Mark Elsen
 - You can do that , but since cisco has announced https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/wireless-ewc-access-point-eol.html
   it's probably better to switch to the native 9800 platforms , you can for instance download and deploy the virtual 9800 controller for free (APs must be licensed)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
Yes you can do that.  And if you are not using DNAC (Catalyst Centre) or any other DNA features then you do not require the DNA license so could select the "Opt out" but as Marce says be aware that due to EWC end of life the software updates for EWC will stop according to the end of life notice.
If you decide to use the APs with 9800-CL (which will be around and updated for the foreseeable future) then you will still require the DNA license.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
