Controller cannot connect to web interface
ahmedabdellatif
Frequent Visitor
Frequent Visitor
I have an 1850 access point . It is working fine as an access point and I can SSH into it no problem, however, I cannot access the web interface using any browse
this problem started before two days ago
before that  I accessed the web interface using any browse
now
When I connect using https, it prompts me for the username and password and then returns:
This page isn’t working x.x.x.x didn’t send any data.
ERR_EMPTY_RESPONSE
 can anyone helps me please ?
2 Accepted Solutions
ash.upadhyay
try config network mgmt-via-wireless enable
10 Replies 10
balaji.bandi
is the AP acting as Mobility express ? what Logs you see when you try to access web on AP ?
have you tried reboot the AP and check ?
I only think of latest browsers with TLS connection issue or certificate expired.
BB
thank you balaji.bandi
yes i tried
the certification will expire in 2030
thank you for the test you have done, as mentioned @Rich R  - try that option.
if you have SSH option (try debug and see what errors you getting when you trying to access Gui from clients)
BB
i tried but no errors found in debug
Rich R
Try re-generating the certificate? config certificate generate webadmin
You will need a reboot after that.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
thank you Rich R
i tried this command then rebooted but The issue hasn't been solved yet
Rich R
Then your options are:
- Open a TAC case if you have a Cisco support contract
- Factory default reset the ME and reconfigure it.
ash.upadhyay
thank you very much ash.upadhyay
the problem solved by the command
again thank you thank you thank you
