Creating & Configuring WLAN by CLI on WLC
Hello Guys.
Thanks again for read me I'm working in a lab beacuase I want to create some template for WLAN's configuration so I decide to create a little user guide.
My general scenario is someting like this:
So I have many questions here:
I already implement 2 wireless network all of them with an external DHCP server I read about some bugs on Internal WLC DHCP server and I don't want to take the risk, so it's the best way have an external DHCP? Can I use Internal DHCP? Can I use internal DHCP just en small networks with a few user?
HOW I SET UP MY WLAN's?
Well I'm not an expert but Always I have one VLAN in my witch L3 for WLAN in most of the case /24. So Always create Dynamic interfaces for every WLAN.
IS THIS A GOOD WAY THE IMPLEMENTED A WLAN?
Now I'm working in the same way with CLI on WLC so if I have everything ready in my wired network I just need configure my dynamic interface and my WLAN so this that I have.
For Dynamic Interface:
config interface créate  <interface_name|vlan_id>
config interface vlan <interface_name|vlan_id>
config interface address dynamic-interface <interface_name|ip_ad|mask| gateway>
config interface dhcp dynamic interface <interface_name|primary/secondary|ip_add>
config interface port <interface_name| physical port>
For my WLAN:
config wlan create <wlan_id| profile_name | SSID_name>
config wlan interface <wlan_id| dynamic_interface_name>
config wlan broadcast-ssid enable <wlan_id>
The problem comes when I try to configure a PSK WPA password for my WLAN I have this error:
(Cisco Controller) >config wlan security wpa enable  10
ERROR: WLAN 10 is already in the requested state.
(Cisco Controller) >config wlan security wpa wpa2 ciphers aes enable 10
(Cisco Controller) >config wlan security wpa akm psk set-key ascii 1234567890 10
ERROR: PSK and/or FT-PSK should be configured on WLAN 10
I'm following the 7.5 configuration manual but It's no working also I'm reading a blog of one friend but still don't work.
Thanks for your advices.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Hellos Guys I have the wpa2 configuration I miss this line:  config wlan security wpa akm psk enable 10
Well I'm not sure if this helps some one but here it's my configuration.
For WPA2 With PSK
config wlan create
config wlan enable
config wlan security wpa wpa2 enable
config wlan security wpa akm 802.1x disable
config wlan enable
Hi Daniel,
When you create a WLAN (GUI or CLI), certain features are enabled by default. For example following are default when you create a WLAN
1. Broadcase enabled
2. Interface map to management interface
3. WPA2/AES & dot1x enable
4  WMM-Allow
5. CHD, Session timeout, Aireonet IE, client exclusion, mDNS, optional client MFP
Therefore you do not want to add configuration line for these features (unless you want to disable these feature). Therefore here is the minimum configuration required if you want to create WPA2/PSK WLAN via CLI.(unwanted lines of your config are shown in strike-trough)
config wlan create
config wlan enable
Here is the some of my reference notes, keep in mind I have done these post based on WLC 7.0.116.0 code & you have to refer the config guide respect to WLC code you are using
1 http://mrncciew.com/2013/05/16/wlan-config-via-cli-part-1/
2. http://mrncciew.com/2013/05/16/wlan-config-via-cli-part-2/
3. http://mrncciew.com/2013/05/16/wlan-config-via-cli-part3/
4. http://mrncciew.com/2013/05/17/wlan-config-via-cli-part-4/
5. http://mrncciew.com/2013/05/17/wlan-config-via-cli-part-5/
6. http://mrncciew.com/2013/05/20/wlan-config-via-cli-part-6/
7. http://mrncciew.com/2013/02/27/configuring-dynamic-interfaces-on-wlc/
Rasika
**** Pls rate all useful responses ****
Abha Jha
