DHCP Issue on a wireless subnet via WLC 3504
Kim131
Hey guys,
I have a DHCP issue on one of the subnets 10.0.1.0/22. IP addresses are released well however only with IP addresses between 10.0.1.1-254 are able to access internet ( browse ) the rest of the users up to 10.0.3.254 cannot browse. tried to queries DNS records for a particular domain name using NSLOOPUP but still it is not working.
your assistance, please
4 Accepted Solutions
RoadRunner4k
Which software are you running ? and is there an external DHCP handing out the IPs?
Is the mask correct on clients not able to access internet ?
Do you got a firewall / router infront to NAT users to internet ? then check if they allow the full subnet of /22
90% of this issue is from the different mask between
1- GW interface
2- DHCP Pool
3- NAT list
this mismatch lead to this case
MHM
Sounds like the subnet mask or the gateway is incorrect in the DHCP scope.
Or upstream firewall/ NAT rule has wrong mask for the subnet
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Kim131
Hi Guys,
Thank you very much for your responses. it was the wrong subnet mask on the interface gateway on the firewall.  It was /24 instead of /22.
6 Replies 6
RoadRunner4k
1- GW interface
2- DHCP Pool
3- NAT list
MHM
Rich R
To add to the list of likely mistakes - wrong subnet mask in an ACL.
Kim131
Hi Guys,
You are so welcome
MHM
